help with splitter - AVS Forum | Home Theater Discussions And Reviews
Old 08-24-2013, 06:19 AM - Thread Starter
twindecks's Avatar
hi can anyone help I have a lindy hdmi splitter 32588 4 port I am running 2 x 15m leads to 2 tv I need to run a third tv which is about 40m will my unit run it or will I have to get a booster to put on the cable
twindecks is offline
Old 08-24-2013, 09:25 PM
AV_Integrated's Avatar
Quoted: 978 Post(s)
Liked: 721
At 40m you should use a HD-Base-T system, not a standard cable. A good HDMI cable generally can hit 50-75 feet (15-25m or so). But, you are talking about twice that distance which means you don't just need an equalizer, you need something better. HD-Base-T can handle that distance with no issue at all.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 08-25-2013, 11:30 AM - Thread Starter
twindecks's Avatar
Is that the only way to go , or is there a cheaper way of doing it
Old 08-25-2013, 01:49 PM
Colm's Avatar
Liked: 94
Originally Posted by twindecks View Post
...is there a cheaper way of doing it
There is always a cheaper way. There are equalizers that claim to be able to deliver 1080p60 at that distance. There are less expensive extenders that claim to do the same. HDBaseT is the only technology that is pretty much guaranteed to work without trouble given the appropriate cabling. What is your time worth?
Colm is offline
Old 08-26-2013, 09:50 AM
alk3997's Avatar
Liked: 92
Basically the cheaper way is under the "How lucky do you feel today?" category. You can try to link 120 feet (roughly 40m) of HDMI cable. If the bandwidth is low enough it will work. If not you'll probably get no picture although you could get sparkles or lines. This is caused by bit errors.
If you use the suggested HDBaseT (or other forms of cat 6 extension) then you will (not may) get all of the bits through.
Standard HDMI was not designed for the lengths you want to go.
alk3997 is offline
Old 08-27-2013, 03:52 PM - Thread Starter
twindecks's Avatar
So if I use a cat 6 cable from the tv to a cat 6 box then plug hdmi lead in it will work I have a link if this will do http://www.amazon.co.uk/gp/aw/d/B002ECYEYA
Old 08-27-2013, 04:30 PM
alk3997's Avatar
Liked: 92
There aren't many specs there but that is the idea. What you want to make sure is that the box isn't doing any type of compression. I can't tell from the limited information unfortunately. A manufacturer's site would probably have that info.
alk3997 is offline
Old 08-27-2013, 06:15 PM - Thread Starter
twindecks's Avatar
Just one more question how do I plug the cat 6 into the tv, is it going to be like dvi plug
Old 08-27-2013, 10:50 PM
Quoted: 978 Post(s)
Liked: 721
No.
Two boxes, one at the TV, one at the source.
You plug HDMI into the source, then plug it into the transmitter box. Out of the transmitter box is cat-5/6 cable. It goes in to the receiver box. Then you come out of the receiver box via HDMI and into your TV with that HDMI cable.
You basically are taking HDMI at both ends, and converting it to cat-5/6 in between.
A RJ45 connection on your TV is for networking, and video extension over cat-5 is not a 'networking' connection, it is just using wire to take an actual HDMI signal further.
Note - The item you linked is very inexpensive as cheap HD-Base-T starts at around $200. So, if you go down that path, be darn sure they have a good return policy and be prepared to use it.
Old 08-28-2013, 02:59 AM - Thread Starter
twindecks's Avatar
I understand now I think that is the cheaper way as I have to pay for it , as my boss won't
Old 08-30-2013, 05:58 AM
Joe Fernand's Avatar
Quoted: 283 Post(s)
Liked: 167
‘as my boss won't’ – time for a new ‘boss’, assuming he/she is making the financial gain from the system!
HDMI can be far from straightforward so connecting up devices in an ‘untested’ configuration may/may not work and as AV-I advises ensure you have a good returns policy on any kit you haven’t tried out before.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
