Monoprice Redmere vs Amazon High Speed - HDMI Cables. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-23-2013, 01:17 PM - Thread Starter
Kenneth Tong's Avatar
Monoprice has this forums support but Amazon has the scale, who makes the superior cable and how does one even compare?
Kenneth Tong is offline
post #2 of 16 Old 09-23-2013, 01:40 PM
alk3997's Avatar
Liked: 92
How is the 4K TV working out?
As for the answer to your question, as long as you get a High Speed HDMI cable (must say so on the advertising) and it's certified, then you have the best cable you can buy. Even if you spend more money, the bits are the same coming out.
The only variable is build quality. We can discuss that, but I need to know how long of an HDMI cable you need?
Just remember these are digital cables, so as long as you don't get bit errors, you're golden.
alk3997 is offline
post #3 of 16 Old 09-23-2013, 01:45 PM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
Amazon has little in the way of quality control more or less which should always be of concern.
There are cables out there from multiple vendors which hit price points all over the place from just a couple of bucks to hundreds of dollars for a 2m cable. Monoprice is respected across the Internet community because they were one of the first to blow the bubble off of high HDMI cable pricing, and have maintained that mentality since their inception. The reviews on their site for each and every cable speak to this fact.
On shorter lengths, I've used the ultra thin cables from Parts Express as a good alternative to Monoprice.
I have never purchased a HDMI cable from Amazon, and I've heard some horror stories which make me worry, but for the most part, I would just read the reviews and decide from there.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #4 of 16 Old 09-23-2013, 01:54 PM - Thread Starter
Amazon have their own brand of cable which works thus far, I will try a Monoprice Redmere from the Time Warner Cable Box to the 4K TV.
post #5 of 16 Old 09-23-2013, 01:56 PM - Thread Starter
The 4K Television is stressing me out cause I had the 4K resolution working perfectly with SwitchResX, then I decided to Tweak it and lost all progress!
I have measured from the Cable Box to the TV, 8FT. My TV Room, is 11.545FT and 14.709FT, 170Ft Squared roughly.
post #6 of 16 Old 09-23-2013, 02:04 PM
alk3997's Avatar
Liked: 92
8 Feet means you are in good shape with any HDMI cable that is High Speed. At 8 ft I would recommend against the Redmere cable unless you really need a thin cable.
The reason is that the Redmere cable is an active cable that restores the waveform at the destination. 8 feet isn't long enough to really need an active component and is just one more item that could fail.
Instead try one of the Monoprice passive High Speed cables. Such as...
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3993&seq=1&format=2
This cable also has the advantage that it should work with HDMI 2.0.
This should also work:
http://www.amazon.com/AmazonBasics-High-Speed-HDMI-Cable-Meters/dp/B003L1ZYYW/ref=sr_1_2?ie=UTF8&qid=1379966731&sr=8-2&keywords=hdmi+10+foot+high+speed
If you were approaching 25 feet, I would have a different recommendation, but at 8-10 feet you should have plenty of choices for not a lot of money.
Kenneth Tong likes this.
alk3997 is offline
post #7 of 16 Old 09-23-2013, 04:33 PM - Thread Starter
Thanking you for your comprehensive reply.
post #8 of 16 Old 06-29-2014, 02:28 PM
bodean's Avatar
Quoted: 170 Post(s)
Liked: 42
I actually have my eyes on the 6ft Slim Series High Speed HDMI® Cable w/ RedMere® Technology
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
post #9 of 16 Old 07-01-2014, 03:13 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
There is Zero requirement to go ‘active’ for a 6’ cable.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #10 of 16 Old 07-01-2014, 03:50 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
^^^^ agreed. At 6', Redmere is an overkill and you could probably just get by with thinner gauge wire if a thick wire is an issue.
Speaking of Andy, where's he been? I haven't seen him post in a long time.
Otto Pylot is online now
post #11 of 16 Old 07-02-2014, 10:12 AM
Quoted: 281 Post(s)
Liked: 164
'Speaking of Andy, where's he been? I haven't seen him post in a long time' - hopefully off creating the HDMI 'Bible'
Joe
post #12 of 16 Old 08-06-2015, 03:48 PM
rsb1445's Avatar
HDMI Cables
Hi, I just ordered a Sony 1080p HDTV and am confused about which HDMI cables to get. I will probably buy from Monoprice, but they have a lot of different types of HDMI cables. I want to hide the cables by running them thru the wall with a box in back of the TV and the other down near the floor. Anybody know who makes the boxes and where I can find them.
Would these Redmere cables be the best choice or does Monoprice sell others that are rated for thru the wall use. Also what is CL2 vs CL3. Thank you in advance.
rsb1445 is offline
post #13 of 16 Old 08-06-2015, 09:03 PM
Otto Pylot's Avatar
Liked: 852
Certified passive high speed HDMI cables are all you need. Current certification is up to 25' so if you purchase a certified cable, make sure it is certified for the length you purchased. Longer than 25' you could go with a thicker gauge passive cable or an active cable with Redmere technology. Keep in mind that a thicker gauge cable will not be very flexible so if you have bends etc it may be a little difficult. Also, a thicker gauge cable will put more strain on the HDMI inputs.
How long of a run will you have and if you are running them thru the wall, is it from one side of the wall to the other or are you installing the cable down the inside of the wall? The length will determine somewhat the kind of cable and installation.
Redmere cables are active cables in that they have a chipset in the sink side (tv) that draws a little power. That's why the cables can be really thin and run at lengths longer than 25' with no issues. They are uni-directional so you have to pay attention to the direction you are installing them. Because they are active cables, they need a direct connection from source to device. Switches or wall connectors may be a problem. Redmere cables are great for those long lengths but are a bit of an overkill for shorter runs. I use them for short runs because I like the flexibility but I probably could have gotten by with thin passive HDMI cables.
CL2/CL3 are fire ratings for in-wall use.
post #14 of 16 Old 08-08-2015, 10:30 PM
rsb1445's Avatar
Hi,
Thanks for your reply. I need 10' cables. I am running it straight down the inside of the wall.
rsb1445 is offline
post #15 of 16 Old 08-09-2015, 10:22 AM
Otto Pylot's Avatar
Liked: 852
Use conduit! A 10' straight run is not bad but I'd still install the cable in a conduit. You will eventually have to replace the cable as spec and cable requirements will change over time so using a conduit makes it so much easier to swap out cables should a problem or requirements change. Keep in mind that Redmere cables have a little chip-set in the sink end so like any other electronic device, they can fail. Another good reason for using a conduit with an active cable. However, at 10' ( I'm assuming that is your maximum distance) you could get by with any certified, passive, high speed HDMI cable because distance is not a factor.
post #16 of 16 Old 08-10-2015, 01:02 PM
Quoted: 972 Post(s)
Liked: 718
I'm thinking with a 10' run he likely is within the same duct going up/down the wall and doesn't need conduit. Maybe not, but typically 10' is the length I use when I'm just dropping a cable down behind a wall from the TV to the source.
I have personally used these with excellent results (and the ratings agree with my experience)...
http://www.amazon.com/gp/product/B00...ilpage_o07_s00
Not sure if they are CL2 rated, I haven't used them in a wall.
I've also used the Monoprice Redmere ultra slim cables behind the wall with great results. Always in a short chase so they can be swapped out easily if need be.
http://www.monoprice.com/Product?c_i...seq=1&format=2
There are a ton of well reviewed HDMI cables at 10' and less out there. Most are very good and will work with pretty much any setup.
Reply HDMI Q&A - The One Connector World
