HDMI setup on TV and Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-04-2013, 11:56 AM - Thread Starter
tcassem's Avatar
This sounds so simple.  I want to run my components (DVD, Roku) through my receiver to my TV.  It has worked in the past so I don't know what is wrong.  My TV says I'm not getting a signal.  From my receiver, I run HDMI out to HDMI in on the TV (I have four HDMI inputs on my Sony TV.  I then connect my DVD player to the back of the receiver (HDMI 1).  I try to do the onscreen setup and still says "no signal, check the external input.  I have set the receiver HDMI 1 for DVD.  I don't understand why this is not working.  Should note that it has in the past taken time before it would show up on the TV.  All of a sudden the DVD or Roku player just starts working on the TV.  I don't understand and would appreciated help.
TV is a Sony with four HDMI inputs
Receiver is a Onkyo with four HDMI inputs
tcassem is offline
post #2 of 5 Old 10-04-2013, 12:17 PM
AV_Integrated's Avatar
Quoted: 993 Post(s)
Liked: 728
Have you updated the firmware on the Sony TV and the Onkyo receiver (if they are Internet enabled)? This is often the first thing which you should do for any products using HDMI and having issues.
If you have done this and still have the same issue, then have you tried connecting your Blu-ray Disc player directly to the TV using the existing HDMI cable currently connected to the A/V receiver? This is not a 'permanent' solution, just a check to ensure that the cable appears to be working properly.
What length are the HDMI cables? Where were they purchased from?
I'm sure you'll get some other ideas here, but I would start by looking at the cabling that is in place.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 5 Old 10-04-2013, 12:23 PM - Thread Starter
tcassem's Avatar
Im not sure how to update the components but can look into that.  I did connect the DVD player directly to the TV and it worked fine.  I think my cables are maybe six feet long.
tcassem is offline
post #4 of 5 Old 10-04-2013, 12:26 PM - Thread Starter
tcassem's Avatar
The tv software says it is current and up to date.  I don't know how I would update the receiver.
tcassem is offline
post #5 of 5 Old 10-04-2013, 12:31 PM
Quoted: 993 Post(s)
Liked: 728
What make of Onkyo receiver do you have? Exact number?
Reply HDMI Q&A - The One Connector World
