Looking for advice on HDMI cable and wall plate to use for 40ft run - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2013, 11:06 PM - Thread Starter
stahara's Avatar
I am putting in a home theater in the basement. I want to run a 40 ft hdmi cable from my receiver to an HDMI wall plate. I plan to use this connection for my Xbox360 (and Xbox One later). I was going to use a Monoprice Redmere cable but when I tested it with a keystone HDMI port the it didn't work. When the cable was used directly, it worked fine.
Does anyone have a suggestion of which Monoprice cable I should use for my in-wall run for this appliaction?
Should I run the HDMI cable into a box or just run the cable to the spot and use a 1-Gang Low Voltage Mounting Bracket?
I would appreciate any help.
stahara is offline
Old 11-04-2013, 09:35 AM
alk3997's Avatar
Liked: 92
DId a regular (non-Redmere) cable work with the keystone? I'm wondering if you have a damaged keystone connector.
alk3997 is offline
Old 11-04-2013, 10:05 AM
AV_Integrated's Avatar
Quoted: 988 Post(s)
Liked: 728
I use this one regularly, and I have not had an issue with runs of about 50' in multiple installations:
http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024002&p_id=4034&seq=1&format=2
I would then take it to this wall plate:
http://www.monoprice.com/Product?c_id=104&cp_id=10425&cs_id=1042501&p_id=7330&seq=1&format=2
Yes, it's always better to go directly from source to destination without a wall plate, but that's just not always possible.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
Old 11-04-2013, 11:06 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
My rule of thumb is it can be seen connecter type wall plate if not use a low voltage mounting plate, running cables right to the input or output whatever the case my be. In this case I think it may be good to try a deferent keystone
and make sure that the Redmere is running the right way, they a directional.
Phil17108 is offline
Old 11-06-2013, 10:05 PM - Thread Starter
stahara's Avatar
I did test the keystone hdmi with passive cables and it worked fine.
stahara is offline
Old 11-07-2013, 03:30 AM
Joe Fernand's Avatar
Quoted: 286 Post(s)
Liked: 167
I’d be ensuring you are running at least one spare CAT6 alongside any HDMI cable plus ensure the cables are easily replaced (big bore conduit is good) – HDMI cables can and do fail.
I don’t get the big rush to cables with inbuilt electronics – they are a potential pinch point when the electronics become obsolete!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
