Need Help With HDMI Switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2013, 07:02 PM - Thread Starter
pentiumvi's Avatar
Hello Guys,
Here's my situation:
I want to connect my PS3 and my soon-to-be PS4 to my computer monitor. I understand I'll need to use a HDMI switch to switch between the two inputs (PS3/PS4). My main problem right now is what to do about audio?
I currently have just the PS3 connected, and I'm using it's analog RCA audio output to connect to my speakers using a RCA to 3.5mm adapter. The audio from my PS3 is then connected to a 3.5mm switch, so I can use my speakers for both my PS3 and PC.
Is there anyway I can do this with the PS4 added into the system? I understand that the PS4 does not offer analog audio output, only HDMI and optical.
I was thinking, is there a way that I could split the audio signal from the HDMI inputs and output them either as RCA, 3.5mm or optical?
Would this product do the trick?
http://www.monoprice.com/Product?p_id=5557
Thank you!
pentiumvi is offline
post #2 of 3 Old 11-04-2013, 09:41 AM
alk3997's Avatar
Liked: 93
There are a lot of ways to do this. Since you only care about stereo,
I can't use your link but this one should work:
http://www.monoprice.com/Product?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=2
alk3997 is offline
post #3 of 3 Old 11-04-2013, 09:55 AM
AV_Integrated's Avatar
Quoted: 993 Post(s)
Liked: 729
Yes, it should do exactly what you want. 4x1 HDMI switching with analog 3.5mm stereo output. Both links are to the same part #5557 at Monoprice.
Read the reviews from people because sometimes MP has some sketchy products.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
Reply HDMI Q&A - The One Connector World
