Redmere cables direction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-22-2013, 04:38 AM - Thread Starter
kevmeist's Avatar
I know that Redmere cables are unidirectional, what is not obvious (well, I think I know but want to make sure) is which end goes to which device with a DVR, BluRay player and receiver.
Mine are from monoprice and labeled "TV" at one end and Source" at the other end.
Am I right in saying this?
DVR or BluRay player to Receiver with the "TV" end at the receiver and the "source" end at the device?
Kevin
kevmeist is offline
post #2 of 5 Old 11-22-2013, 07:27 AM
walterappleby's Avatar
Quoted: 26 Post(s)
Liked: 77
The signal needs to go from the SOURCE on a path to the TV.
If you have the cable going from a Blu-Ray/DVR, etc --> Receiver then you have (Blu-Ray = Source, Receiver = TV)
If the cable is used after the receiver then it would be Receiver --> TV/Projector (Receiver = Source, TV/Projector = TV)
Does that help?
Bottom line... plug it it. If it works it's correct. If you get nothing then you need to reverse the direction.
walterappleby is offline
post #3 of 5 Old 11-22-2013, 08:33 AM
Otto Pylot's Avatar
Quoted: 1591 Post(s)
Liked: 998
...and I might add that you won't hurt anything if you plug them in backwards.
Otto Pylot is offline
post #4 of 5 Old 11-22-2013, 09:02 AM
Bwsdfwx's Avatar
It seems clear now thanks for your posts.
AdMfwx
Bwsdfwx is offline
post #5 of 5 Old 11-22-2013, 12:56 PM - Thread Starter
kevmeist's Avatar
Thanks, Walter. for confirming..just what I thought.
Kevin
kevmeist is offline
Reply HDMI Q&A - The One Connector World
