Digital Analog Digital Analog - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-03-2014, 09:13 AM - Thread Starter
videoray's Avatar
Quoted: 37 Post(s)
Is there an outboard "Room EQ" unit that will put digital to a pre A/V unit? Of course in order for the Room EQ to work it must have a DAC to to do measurements
but will bypass the DAC to the Pre A/V unit after setup. I want to use one DAC without converting back and forth from digital to analog than back to digital.
videoray is offline
post #2 of 3 Old 03-03-2014, 11:05 AM
Joe Fernand's Avatar
Quoted: 283 Post(s)
Liked: 166
‘it must have a DAC to to do measurements but will bypass the DAC to the Pre A/V unit after setup’ – I think you are going too ‘flat earth’ with your thinking biggrin.gif
Unless your are very attached to the ‘pre A/V’ unit and or have very deep pockets I’d suggest an AVR with Pre Outs or a dedicated AV Processor to replace or work alongside the current unit.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #3 of 3 Old 03-03-2014, 02:04 PM - Thread Starter
videoray's Avatar
Quoted: 37 Post(s)
Joe
That is right Joe. The dreaming won't do me any good. I don't have the needed deep pockets, either. I have the Oppo 83 for years and like it very much. The 105 is close, but not yet. Hopefully their next unit will have the needed Room EQ.
videoray is offline
Reply HDMI Q&A - The One Connector World
