Best way to run an HDMI cable > 50 feet < 75 feet - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2014, 08:35 AM - Thread Starter
Garet Jax's Avatar
Is it to run one HDMI cable or use an extender or something else?
What are the best HDMI cables on the market for extended lengths?
I have read about Redmere from Monoprice, but I need this to have the highest probability of working. I am debugging a long term problem that I just need to work.
I recently upgraded from PS3 to PS4 and from XBox 360 to Xbox One and the problems got worse. I am now trying to solve this once and for all.
Garet Jax is offline
Old 06-13-2014, 10:36 AM
AV_Integrated's Avatar
Quoted: 981 Post(s)
Liked: 722
The BEST solution is HDBaseT.
Redmere will work, and is designed to work, but it could fail since it has active electronics. I don't recommend Redmere if you are putting it behind drywall for this reason, but using Redmere and running some cat-6 isn't a bad way to do things.
I actually most often use 22AWG HDMI cables from Monoprice and I have had great results.
Cable runs should all be point to point without wallplates between the connections.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 06-13-2014, 11:40 AM - Thread Starter
Garet Jax's Avatar
So if I was to use one of these:
http://www.monoprice.com/Product?c_i...seq=1&format=2
with a cat6 cable connecting them to each other and then a short HDMI cable on each end to connect the source and target, would that be how I use it?
If so, the two 100BaseT plugs are throwing me off. Are they there just to support Cat 5 cabling as well?
Old 06-13-2014, 03:17 PM
Quoted: 981 Post(s)
Liked: 722
HDBaseT supports 10/100 Ethernet over the same cat-6 cable that the HDMI runs down as well as RS-232 and/or Infrared.
So, if you plug your network into the transmitter it will give you 10/100 network connectivity at the other end.
You get HDMI AND network down the single cat-6 cable. Pretty cool huh?
The only wire you need between the source and the destination 75' away is one cat-6 wire. That cat-6 connects to the 'HDBaseT' connection on the boxes.
Old 06-14-2014, 09:54 AM
Joe Fernand's Avatar
Quoted: 283 Post(s)
Liked: 167
What is the long term problem you are debugging and what cables are you currently using?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
Old 06-25-2014, 07:40 AM
thecsigroup.com's Avatar
Liked: 0
A cost effective solution for a high speed HDMI long run, may be the Monoprice RedMere.
http://www.monoprice.com/Category?c_...&cs_id=1025506.
HDbaseT is great technology but if budget is a concern, RedMere may be a good solution.
Since the cable is active, which is somewhat disturbing, you could run a second cable as backup, and still pay less than you would for HDbaseT.
RedMere has all the bells and whistles that HDMI has to offer: Ethernet, audio return channel, CEC, etc...
RedMere is also 4K ready.
The reviews are good, and we recently ordered few cables to try.
Stay tuned...
thecsigroup.com is offline
Old 06-26-2014, 02:56 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
Stay tuned...
Unless you're going to run the cables in-wall. Then you better use a 1" conduit for easy removal/replacement of the cable should it go bad or better yet, as suggested, run CAT-6. It's so much easier to pull a cable with no connectors on either end than it would be to pull a cable with both ends terminated with HDMI connectors.
Otto Pylot is offline
