Is there a meter or gauge to be able to test HDMI signal strength? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2014, 08:19 AM - Thread Starter
Garet Jax's Avatar
Hello all,
I am looking for a way to test the source and target of the HDMI signal strength so I can test it to make sure it is "good enough" for video to the TV.
Thanks a lot.
Garet Jax is offline
post #2 of 5 Old 06-13-2014, 09:34 AM
AV_Integrated's Avatar
Quoted: 1003 Post(s)
Liked: 732
Originally Posted by Garet Jax View Post
Hello all,
Thanks a lot.
Not for the average user.
The best test is to simply hook up a TV and a 1080p source and see if signal passes.
If this is for work that will be done behind drywall, the best rule is to pull conduit, the second best rule is to pull several pieces of cat-6 wire along with the HDMI cable.
HDMI will eventually be gone, so conduit is best, while multiple runs of cat-6 cable give a nice option for extenders.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #3 of 5 Old 06-13-2014, 11:08 AM - Thread Starter
Garet Jax's Avatar
Has anyone tried this product?
or this one?
post #4 of 5 Old 06-13-2014, 12:32 PM
Joe Fernand's Avatar
Quoted: 297 Post(s)
Liked: 175
Are you in the Trade?
What cables are you looking to 'test'?
HDMI signal strength is a function of the Source + Cables + Sink not just the cable alone.
The Cable test units you link to have very limited usefulness - and many of them can be easily 'blown'* if you inadvertently connect to a cable with a 'live' source on the ‘Source’ end of the HDMI cable!
Joe
*And uneconomical to repair if you do pop them!
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #5 of 5 Old 06-18-2014, 08:58 AM
Otto Pylot's Avatar
Quoted: 1402 Post(s)
Liked: 878
I used a similar product when we installed CAT-6 in a conduit to extend our connections. It basically shows if the wiring scheme was connected properly but nothing about throughput or quality of connection.
Otto Pylot is online now
Reply HDMI Q&A - The One Connector World
