Looking for some HDMI cable recommendations for use with a keystone jack - AVS Forum | Home Theater Discussions And Reviews
Old 07-14-2014, 09:12 AM - Thread Starter
RDabate's Avatar
I working on one of my conference rooms and I need to have the cables clean, meaning, I can't just have a extra long HDMI cable from the Projector, and hanging out of the wall. I have a keystone jack for an HDMI cable that I got from monoprice.
Here's what I need, a long cable from the projector to the back of the keystone jack that is at least 35 feet long. The from the other finished side of the keystone jack, a jumper cable will occasionally be plugged into that. This cable needs to be at least 15FT long.
Any suggestions?
RDabate is offline
Old 07-14-2014, 09:19 AM
AV_Integrated's Avatar
Quoted: 988 Post(s)
Liked: 728
Any suggestions?
At 50'+ in total length on this run, with a jumper in between, you really should be looking at 22AWG cable, and you may need an active signal balancer to make this work properly. Are you just going behind walls, or are you going above a drop ceiling? If you are going through the ceiling, is it a plenum space or is it non-plenum?
I would use the Monoprice 22AWG HDMI cable for behind the wall if you are in a non-plenum space. Otherwise, something like this would be required:
http://www.cablestogo.com/product/41192
You will need to consider strain relief or angle of insertion on any HDMI wall connections.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Old 07-16-2014, 01:37 PM
Joe Fernand's Avatar
Quoted: 288 Post(s)
Liked: 168
'I working on one of my conference rooms' - what are you doing for VGA to they Projector?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
