How do I connect my Home Theater ? (HDMI) - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By skuum
  • 1 Post By Otto Pylot
Old 07-26-2014, 01:10 PM - Thread Starter
Liked: 1
I have the following:
Receiver (Yamaha RX-V473) 1 Out, 4 In
TV (Samsung UE46D7005) 4 HDMI in (ARC included)
Digitalbox (1 HDMI)
Projector (Benq W1070) 2 HDMI's
iMac 27" (Thunderbolt>HDMI)
And
HDMI Switch (2 Out, 3 In)
How should i connect all these to receive Audio and Video on all devices?
I tried using TV & Projector -> HDMI Switch > Out 1 & Out 2
And iMac, Receiver & Digitalbox -> HDMI Switch -> In 1, In 2 & In 3
Didnt work duo
skuum is offline
Old 07-26-2014, 01:22 PM
Blindman0v0's Avatar
Quoted: 42 Post(s)
TV and Projector will be on the 2 outs and Receiver and Digital Box on 2 of the ins. Not sure how your audio will work out. I prefer using analog for sound.
Blindman0v0 is offline
Old 07-26-2014, 01:33 PM - Thread Starter
Liked: 1
The problem with this, if I'm correct...
If i select on the Switch i.e Out 1 (TV), I then have to select i.e In 1 (Digitalbox) to receive TV Video, But must i not select In 2 (Receiver) for sound then?
I can only choose 1 Out-signal, and only 1 In-signal at the same time on the Switch, which is standard i think?
skuum is offline
Old 07-26-2014, 01:55 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
You could connect all of your devices via HDMI to the receiver (I'm not sure what you mean by digital box), with a single HDMI cable going out to the tv for video. Turn off the audio on the tv. Disable ARC on all of your ARC capable devices and then get a programmable remote like a Harmony. That way you can easily select your source with one or two pushes of a button.
All of your audio should be played thru the receiver with only the video portion going to the tv. Use certified high speed HDMI cables (Monoprice, MediaBridge, Blue Jeans, etc) and you're good to go. That's how I have mine setup, only my tv is OTA only, so I use an optical cable from the tv to the receiver so I can listen to discrete 5.1 when broadcast (using the internal ATSC tuner).
Otto Pylot is offline
Old 07-26-2014, 02:26 PM - Thread Starter
Liked: 1
I've actually been looking on a Harmony...
Digitalbox is a Cable box
So, If I use my only Receiver-OUT to my TV (Not Arc?)
Then where should my Projector go to? Don't the projector need an HDMI-Out aswell?
skuum is offline
Old 07-26-2014, 03:50 PM
Joe Fernand's Avatar
Quoted: 282 Post(s)
Liked: 166
Possibly simpler to plan out your system if you start at the Sources and work towards the Display devices.
Connect the Sources to the AVR via HDMI then the HDMI Out of the AVR to an Input on the 3x2 Switch and connect the Output(s) of the Switch to the TV and Projector.
ARC only works when the TV and ARC are ARC enabled (and you have HDMI CEC control enabled).
If the 3x2 Switch can be locked to a mirrored Output mode that ought to make things slightly simpler.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
Old 07-26-2014, 04:24 PM - Thread Starter
Liked: 1
Joe
That actually worked very well... Thank you
Joe Fernand likes this.
skuum is offline
Old 07-26-2014, 05:14 PM
Otto Pylot's Avatar
Liked: 853
Joe is a wizard at simplyfing things.
Old 01-05-2015, 11:26 AM
Liked: 0
apple tv -- AVR -- Soundbar + BenQ
skuum,
Here's what I have :
(1) apple tv ( HDMI out, optical out )
(2) blu ray player ( HDMI out )
(3) cable tv set top box ( HDMI out )
(4) pioneer vsx-822 receiver - this is borrowed, I'm willing to buy another .
(5) VIZIO S4251w-B4 5.1 Soundbar with Wireless Subwoofer and Satellite Speakers ( optical in, RCA in, digital in , HDMI in)
(6) benq 1085st ( HDMI in , audio out via RCA )
What I'd like to do :
a) connect 1, 2,3 to 4 .
b) connect 4 to 6 ( HDMI )
b) connect 4 to 5 ( RCA connection red-white males to vizio - this did not work )
Since I mostly watch apple tv, I'd like to get that connected first. 2 and 3 in the future.
I do get picture but no audio. Tried several things including optical out apple tv. Didn't work. And I don't prefer that either.
Is there any receiver that will let me all the devices in HDMI in, and I split the HDMI out, one to the projector and the other to the soundbar with HDMI ? Everyone says this will work but it doesn't .
I'd like to avoid connecting sound from projector.
shanlz is offline
Old 01-06-2015, 09:56 AM
Quoted: 282 Post(s)
Liked: 166
‘Is there any receiver that will let me all the devicesin HDMI in, and I split the HDMI out, one to the projector and the other to thesoundbar with HDMI ? Everyone says this will work but it doesn't’ – can weassume you have a 5.1 Sat/Sub speaker array connected to the AVR for use whenyou are viewing via the Projector?
The Soundbar is effectively an AVR integrated into aloudspeaker chassis - you would not ‘cascade’ the AVR Output to the Soundbar Input.
How best to connect up your system will depend on your answer to the question above.
Joe
