no video output via HDMI... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-09-2014, 05:45 AM - Thread Starter
Liked: 0
Hi everyone!
i was told by a friend that this community is pretty good with helping solve problems so i though i'd give it a go
I was wondering if you could help me out...
i've got a problem with my hdmi output from my laptop to my TV. for some reason i am unable to get video output but i still get audio output.
I have recently needed to restore the laptop to factory settings using the manufacturers ghost image and since then it hasn't worked. i've re-downloaded all the drivers and installed them trying to find some kind of fix but no luck
I know it does work since i've been using the same laptop and hdmi cable for a while now.
if anyone has any ideas on how this could be fixed they would be much appreciated
Windows 7 Home Premium x64
Intel Core i7 3610QM
8GB RAM
Intel HD 4000
Nvidia GT 630M
Cloudx9 is offline
post #2 of 4 Old 08-09-2014, 05:58 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
what hardware?
what does "screen resolution" say?
you should have a function key somewhere button left.
this with a F key should change settings like that i think it is function + f6.
mightyhuhn is offline
post #3 of 4 Old 08-09-2014, 06:32 AM - Thread Starter
Liked: 0
Originally Posted by mightyhuhn View Post
what hardware?
I believe its running through my intel HD 4000
I press F4 and change the mode to either duplicate or projector only but i only get sound, no video.
the tv is still detecting the signal as it doesn't say otherwise and it still outputs sound
Screen Resolution=1960x1280
Refresh Rate= 58i
8GB RAM
Intel HD 4000
Nvidia GT 630M
Cloudx9 is offline
post #4 of 4 Old 08-12-2014, 12:51 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
‘Screen Resolution=1960x1280
Refresh Rate= 58i’ – no wonder it’s not working
Many TV’s will only work with HDTV format signals1280x720@60, 1920x1080@60 – some will also support a limited range of ‘PC’format signals WXGA, XGA etc. (again usually only at a limited frequency range).
Look in the User Manual for your TV – there will be atable outlining what signals the HDMI port supports and you will need to setthe HDMI Out on the Laptop accordingly.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
Reply HDMI Q&A - The One Connector World
