Super thin hdmi vs thicker hdmi cables! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-13-2014, 10:49 PM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
Super thin (spaghetti) hdmi cable vs thicker stiffer cables? Can a super thin hdmi cable produce the same quality, reliability,as a thicker cable? Even without redmere or any kind of chip? If so, how? And what length? Thanks? Also im glad I found this forum, everyone has been great help! Thanks in advance for the expertise! ☺
Plasma5300 is offline
post #2 of 11 Old 08-13-2014, 11:43 PM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
How does a super thin cable without redmere or chip transfer the same data as a thicker cable? Im not understanding why the thick cables if both do the same?
post #3 of 11 Old 08-13-2014, 11:50 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Yes a thin cable well work as long as it's a short run. I wonder about the reliability of the thin cables no mater how long or short it is. I would never put one in the wall or any place that is not easily assessable. I used 22 gage Monoprice cables setting up the TV's in my place with what they call port savers, short 28 gage extension cable that adds flexibility at the ends.
Phil17108 is offline
post #4 of 11 Old 08-13-2014, 11:57 PM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
Take a look here. Lots of information on HDMI cables and cables in general.
http://www.bluejeanscable.com/store/...hdmi-cable.htm
post #5 of 11 Old 08-14-2014, 12:04 AM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
http://m.store.sony.com//slim-high-s...l-TV-AV-Cables
I am using this cable. It is really thin at only 3 feet. Now how can it transmit the same data at the same speed as a cable the same length but thicker?
post #6 of 11 Old 08-14-2014, 12:13 AM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
Any idea what guage cable I have? I posted the link in the post above
post #7 of 11 Old 08-14-2014, 06:48 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 109
If it's working don't sweet it, and read the information on the link that is a few posts up for your answer.
Here is a link to the same information from Monoprice.
http://www.monoprice.com/home/home.asp?pn=help&idx=12
post #8 of 11 Old 08-14-2014, 08:21 AM
SAM64's Avatar
Liked: 78
Gauge really has nothing to do with data rate. read the posted link, take a course on data transmission, or google it.
SAM64 is offline
post #9 of 11 Old 08-14-2014, 08:48 AM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1022
All of the responses are correct. The biggest problem, imo, with a small gauge passive cable is fragility. If your connection works fine (it either works or it doesn't), there aren't any sharp bends, it won't be jiggled around, and you can easily get to it if need be, just use it and don't worry about it.
Otto Pylot is offline
post #10 of 11 Old 08-14-2014, 11:50 AM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
Yea all I really need is a foot. My ps4 is right next to the tv. Thats great! It either works it doesnt, no variations in color or resolution? I agree its super clear with great vibrant colors, no sparkles.
Its just weird how crazy thin this cable is compared to my previous cable which was super think with locking plugs, Seems like it could damage the ports so the reason I went with a light thin cable. 😀
post #11 of 11 Old 08-17-2014, 06:41 PM
AV_Integrated's Avatar
Quoted: 1126 Post(s)
Liked: 819
Since most cables have issues near the head where they connect, the super slim cables really are a god send for the stress relief that is in place. I've hocked the ones from Parts Express from the first day I received one and used it. I've put about 100 now through a $10,000+ HDMI tester with zero failures out of the box, and my installations with them have also produced zero failures. Unlike the thicker cables which also work well, these cables do the same, but don't push the equipment around. Think of lightweight BD players, Roku boxes, and AppleTV units which literally float in the air when connected to a heavy gauge HDMI cable. Forget cable management with them as well.
The skinny cables for short runs are the bomb. I've truly replaced a box which weighed about 20 pounds with one that is 1/10th the size, and holds more cables in it.
At $25, I think that Sony cable is horrendously overpriced, and I've provided plenty of links to the $5 cables I recommended, but whatever, as long as you get great results, then what else matters?
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply HDMI Q&A - The One Connector World
