Help a Newbie with HDMI? - AVS Forum | Home Theater Discussions And Reviews
Old 08-25-2014, 01:01 PM - Thread Starter
Liked: 0
I would like to connect the following:
Cable box to two HDTVs.
Blue Ray player to the same two HDTVs.
Switch from Blue Ray to Cable box as source.
The distance are three feet to one of the HDTVs three feet to the other is 50 feet.
I figure it would take two splitters with a switch to each splitter for controlling the source.
Would I need an amplifier for the longer run?
Anything else I need to know? What am I missing?
jshaw42 is offline
Old 08-25-2014, 01:45 PM
Otto Pylot's Avatar
Quoted: 1372 Post(s)
Liked: 858
The current maximum certified length for passive HDMI is 25'. Any HDMI cable that has a certification available for the length of cable you purchase will meet or exceed the current HDMI 1.4 hardware specs as well as the new HDMI 2.0 hardware specs. Lengths longer than 25' can be achieved with either a thick gauge cable or better yet, an active cable like Redmere. If you're going to run the longer cable in a wall, then I'd suggest using a 1" conduit and possibly a CAT-6-HDBT connection. I'll leave the active switches up to someone else.
Otto Pylot is offline
Old 08-25-2014, 03:05 PM - Thread Starter
Liked: 0
Thanks for the quick and helpful response.
Am I understanding correctly that the active cable would avoid the necessity of an amplifier in the system? Would a splitter reduce the current?
I have installed the larger, blue, flexible low voltage conduit for running the cable. I believe it is a bit larger than 1". At least there is enough room for more than one cable.
jshaw42 is offline
Old 08-25-2014, 03:34 PM
Otto Pylot's Avatar
Liked: 858
You could run a Redmere cable (they are uni-directional so pay attention to the orientation. The cables are marked) which is an active cable in that all of the electronics are in the sink end (tv side) and draw very little power from the HDMI input. The downside of Redmere is being as they have a chipset in one end, they could fail over time like any electronic device. However, if you're running them in a conduit, which sounds like you're doing, replacing the cable would be relatively easy because you could just pull a new one (as long as you don't have any harsh bends in the conduit). If it were me though, for a 50' run I'd use CAT-6 for that length and then HDBase-T. That's going to be a bit more expensive but the use of CAT-6/6a, at least for that connection, is about as future-proof as you're going to get.
Old 08-26-2014, 01:33 PM - Thread Starter
Liked: 0
Thanks, again, Otto. I spoke with Monoprice and they also recommended Redmere (why am I not surprised?). They also recommended the Matrix 2x2, which has an amplifier.
Whatever route I take, I will gladly report back here the results.
jshaw42 is offline
Old 08-26-2014, 02:41 PM
Joe Fernand's Avatar
Quoted: 291 Post(s)
Liked: 168
'Anything else I need to know? What am I missing?' - how are you planning on controlling the kit?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
Old 08-27-2014, 11:52 AM - Thread Starter
Liked: 0
Sorry, Joe. I'm not sure what you mean.
jshaw42 is offline
Old 08-27-2014, 11:56 AM
Quoted: 291 Post(s)
Liked: 168
How are you planning to control the Source devices (and potentially the Matrix) on the end of the 50' cable run?
Joe
Old 08-27-2014, 01:29 PM - Thread Starter
Liked: 0
Well, my desire is to connect my DVD player and Cable box at one end of the 50 foot cable with an HDTV at the other end. There would be only a three foot run from the switch to the main HDTV. Does that answer the question or am I missing something?
jshaw42 is offline
Old 09-15-2014, 07:19 AM - Thread Starter
Liked: 0
Bought the Redmere 50 foot HDMI and the 2x2 splitter from Monoprice. Gave it a test yesterday and it works great. My problem is the conduit installed by the electrician is too narrow to run the cable. Bummer! But the contractor is going to remedy that in some fashion. I hope.
jshaw42 is offline
