WDTV live box - Only 1 hdmi output - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2014, 01:23 PM - Thread Starter
Liked: 1
So I got a WDTV live box - unfortunately it only has one HDMI output. This means that I have to switch HDMI cable between my TV and projector depending on which screen I want to use.
I have read about HDMI splitters - would such a device allow me to have both my projector and TV screen connected at once to my WDTV live box?
I have attached a picture of a HDMI splitter. So the idea is that I connect the splitter to the WDTV live and the plug both my tv screen and projector into the splitter. Hope I have explained myself good enough
thadudedk is offline
Old 09-04-2014, 01:42 PM
ebo
ebo's Avatar
Quoted: 58 Post(s)
That should work. I have a WDTV Live Plus with HDMI out to 1 input of a 4x2 matrix switch, 1 output of which feeds a 1x2 splitter (both Monoprice). No problems, at least none that aren't caused by !@#$%^ DRM requirements.
ebo is offline
Old 09-04-2014, 03:23 PM - Thread Starter
Liked: 1
Good to hear! Just to be sure - is this the way you have done it too? Not sure I understood your setup 100% (See my drawing - lol)
Btw. For the seup on my drawing - do I need a HDMI switch or HDMI splitter?
Name:	WDTV split.png
Old 09-04-2014, 11:43 PM
ebo
ebo's Avatar
Quoted: 58 Post(s)
That's not quite like my setup--I have a matrix switch between the WDTV and the splitter, with other inputs on the switch as well--but your drawing is correct for what you want to do. And you do want a splitter for that job, not a switch.
There's no guarantee that any given splitter will work with all your devices because of the aforementioned DRM stupidities but the only problem I've had with mine was when I was feeding one output to HDMI In on a projector and the other to DVI In (through an adapter) on a computer monitor. Sometimes it worked, sometimes I got a colorspace mismatch on one of the displays (shows as pink or green tint, like The Matrix only worse). My solution was to replace the monitor with one with HDMI In.
ebo is offline
Old 09-05-2014, 09:07 AM
Joe Fernand's Avatar
Quoted: 285 Post(s)
Liked: 167
Ensure any Distribution Amp 'splitter' you install has an external PSU and is not trying to 'steal' power from the Source device HDMI socket.
http://www.octavainc.com/HDMI%20dist...02%20port.html
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
