Is HDMI with Ethernet cable useless? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-15-2017, 06:22 AM - Thread Starter
2Charlie's Avatar
Quoted: 96 Post(s)
I found this video that talks about HDMI with Ethernet being useless.
Do I need to have my AV or whatever device that the HDMI with Ethernet will connect to able to accept the Ethernet part of it? If so, when looking at those devices, what should be I looking at specifically?
2Charlie is offline
post #2 of 4 Old 09-15-2017, 09:15 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Yes.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 09-15-2017, 10:45 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
+1. The device mfrs never adopted that HDMI spec so when you see it advertised as a spec, it's totally meaningless. The HDMI channel may be used (for eARC) once HDMI 2.1 is implemented but that is far from certain. Even if it is, current HDMI cables won't be able to handle the 48Gbps bandwidth needed for fully compliant HDMI 2.1 so you'll need a new cable (probably very expensive) and HDMI 2.1 chipsets in your devices and cables (if active).
Otto Pylot is online now
post #4 of 4 Old 09-15-2017, 06:26 PM - Thread Starter
2Charlie's Avatar
Quoted: 96 Post(s)
Awesome! Thank you.
2Charlie is offline
Reply HDMI Q&A - The One Connector World
