Can anyone confirm connector diameter of Ruipro? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-18-2017, 05:49 AM - Thread Starter
lawsondl's Avatar
Hi: Looking at purchasing the the Ruipro fiber cable, but need to know what size hole is needed for it to pass through (need to drill through a stud). Can someone pass on the diameter of the connector?
Dan
lawsondl is offline
post #2 of 4 Old 09-18-2017, 08:17 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
http://www.ruipro.com/index.php?rout...mation/contact
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 09-18-2017, 08:31 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
If you're drilling thru a stud I'd install a 1.5" - 2.0" conduit and then run the cable thru that. The only way to "future proof" in-wall cable installations is with the use of a conduit. Video standards are becoming more demanding in their cabling needs and if you ever need to replace an optical cable, or any cable for that matter, having it installed in a conduit will make that so much easier. It's also easier to control bend radius which may affect your signal. I'd thoroughly check out the cable before installing it just to make sure that you received a good cable and that it meets your expectations.
Otto Pylot is offline
post #4 of 4 Old 09-18-2017, 10:05 AM - Thread Starter
lawsondl's Avatar
Received a quick response from their tech supprot. Width is 18.72 mm at the widest, so pretty narrow. Nice!
Dan
lawsondl is offline
Reply HDMI Q&A - The One Connector World
