Is there a way to test HDMI bandwidth? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-18-2017, 06:52 PM - Thread Starter
ToiletDucky's Avatar
Quoted: 21 Post(s)
I have cables I personally buried in my wall during a remodel. They're about 6ft long. I currently have my htpc plugged into my Yamaha that goes to my 4K TV. I'd like to know if I just need to replace the receiver or the cabling too to take advantage of everything. Is there some way I can use my htpc to test the bandwidth? I'm a little confused now if someone could take a look at my receiver.
https://www.yamaha.com/cchtr4065/default.asp
In the past it hadn't mentioned 4K. Even when I plugged in my htpc it had big issues with zero sound until I upgraded the firmware. So does this now mean my receiver doesn't need replacing? Again I do everything through a htpc for now.
ToiletDucky is offline
post #2 of 2 Old 09-19-2017, 02:51 PM
Joe Fernand's Avatar
Quoted: 404 Post(s)
Liked: 224
'4K' is a bit of a catch all phrase which can be misleading at times.
It looks like your AVR will be fine with some '4K' Sources - what is not so clear is will it work with 4K UHD Sources which require support for 3860x2160 at 60/50/24p with HDCP 2.2, many 'older' devices labelled as '4K' only support HDCP 1.4 and can be limited to 3860x2160 at 30/25/24p. It will therefore depend on which Sources you intend to work with.
Your cables are likely OK for 4K UHD as they are relatively short - time will tell though!
Joe
Octava Inc. Multi-cast HD over LAN solutions.
Ruipro UK and EU Sales and Support
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is online now
Reply HDMI Q&A - The One Connector World
