What's the best wireless HDMI? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Pyronaut
post #1 of 6 Old 09-21-2017, 10:41 AM - Thread Starter
2Charlie's Avatar
Quoted: 95 Post(s)
Has anyone successfully use wireless HDMI that works in an environment where it's not in line-of-sight? If so, what brand/model have you tried? I wonder if anyone has tried the J-Tech Digital HDbitT Series Wireless HDMI Extender 660 Ft Supporting Ultra HD 4K with IR Signal Transmission and what is your opinion about the product?
2Charlie is offline
post #2 of 6 Old 10-16-2017, 08:24 PM
Pyronaut's Avatar
Quoted: 29 Post(s)
Depends what you want it for. I've used wireless HDMI products from IOGear and Air3C. I prefer the Air3C, but the IOGear can go through walls much better, and can output to 2 devices at the same time. I didn't need that, but you might. The IOGear uses WHDI, which causes compression artifacts around text, but the Air3C uses WirelessHD and doesn't do that most of the time. It doesn't have to have line of sight (it bounces the signal off walls) but it will perform better if it has it.
I have a couple of posts in the another thread here and here that document my experiences with Wilress HDMI.
2Charlie likes this.
Pyronaut is online now
post #3 of 6 Old Yesterday, 07:52 AM - Thread Starter
2Charlie's Avatar
Quoted: 95 Post(s)
Thank you. I will give your threads some readings.
2Charlie is offline
post #4 of 6 Old Yesterday, 01:53 PM
Joe Fernand's Avatar
Quoted: 405 Post(s)
Liked: 224
What are you looking to use a Wireless HD Extender for?
None of them are equal to using a cable - add in any requirement for 4K UHD and none of them are any good.
Joe
Octava Inc. Multi-cast HD over LAN solutions.
Ruipro UK and EU Sales and Support
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is offline
post #5 of 6 Old Today, 11:00 AM - Thread Starter
2Charlie's Avatar
Quoted: 95 Post(s)
Joe
Yeah, that's what I'm afraid of. I was hoping for easy installation...no wiring involve. I'm trying to run hdmi to my multiple room TVs.
2Charlie is offline
post #6 of 6 Old Today, 02:02 PM
Quoted: 405 Post(s)
Liked: 224
Time to plan out those wiring runs!
Joe
Reply HDMI Q&A - The One Connector World
