Do All HDMI Cables carry 1080P? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-20-2007, 03:07 PM - Thread Starter
tomhetzel42's Avatar
Do all HDMI cables carry the same signals? I have a Sanyo PLV-Z4 and a Samsung 860 DVD player. I need a cable about 12 feet long and man are there more options than I want to deal with. So that said, is there any difference in cable besides insullation and thickness? Can a $60 cable do the job or do I need the $275 version? Please help!!!
tomhetzel42 is offline
post #2 of 8 Old 01-20-2007, 04:24 PM
ericsilv's Avatar
try monoprice you could do 1080p hor a lot less then $60
ericsilv is offline
post #3 of 8 Old 01-20-2007, 04:35 PM
HerryPotter's Avatar
Quick Answer - Yes!
HerryPotter is offline
post #4 of 8 Old 01-21-2007, 01:19 AM
SoCalMacDude's Avatar
I have a 32 ft HDMI run using 2 cables, $20 ea at RiteAV, connected with their coupler, about $5, and it works great! MonoPrice may even be cheaper!
SoCalMacDude is offline
post #5 of 8 Old 01-21-2007, 12:51 PM
madkaw's Avatar
Liked: 31
Yes, a salesman at one of the big box stores told me that only brand that carries 1080p is Monster. I just shook my head and walked away.
ISF Certified Calibrator
CalMan Pro
Electronics Junkie
madkaw is offline
post #6 of 8 Old 01-22-2007, 08:11 AM
MJGTC's Avatar
I can't get a great pq on my 46" 1080p Sharp Aquos LCD from my samsung blu-ray player. It looked better on the Samsung 1080p LCD. Are there communication problems between 1.2 and 1.3 because of the chip set or could it be the Rocketfish hdmi cable I have?
MJGTC is offline
post #7 of 8 Old 01-22-2007, 11:46 AM
jwatte's Avatar
1.2 and 1.3 are compatible. You should get the best picture quality that the equipment can agree on.
An HDMI cable either works, or it doesn't. If it doesn't work, you'll get some sparkles in the image (very noticeable), and very quickly it'll lose sync and not work at all. Picture quality such as resolution and definition is not affected by the cable.
When looking at the Sharp and Samsung side-by-side, I've noticed that the Sharp appears to be doing significant de-blocking, whereas the Samsung isn't. This means the Samsung is "sharper," but also noisier. See if you can find an adjustment on the Sharp to turn that off, and see if you like that picture better.
jwatte is offline
post #8 of 8 Old 01-24-2007, 10:28 PM
HDMI_Org's Avatar
Please see my post here detailing information on HDMI cables:
http://www.avsforum.com/avs-vb/showthread.php?t=794088
HDMI_Org is offline
Reply HDMI Q&A - The One Connector World
