Denon 3806 HDMI Audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-27-2007, 01:23 PM - Thread Starter
has3806's Avatar
Hello All,
I just bought the 3806 but having difficulty setting it up...
I am not getting any AUDIO through my Receiver... BUT can get Audio through TV. I understand I am suppose to set as follows:??
Video Set up --> HDMI In Assign --> DVD to HDMI-1 and HDMI Audio to "AMP" for receiving sound though AMP... it says NO SIGNAL
when i play I get a HIGH PITCH sound from the speakers...
My connection is:
DVD HDMI OUT to Receiver HDMI-1 IN
Receiver HDMI OUT to my Pioneer Plasma Receiver HDMI IN
I didnt connect anything else to the receiver (ONLY DVD)
I dont know what else to do... I am stuck..
has3806 is offline
post #2 of 7 Old 01-27-2007, 02:29 PM
ptsenter's Avatar
connect dvd coax or optical to receiver
ptsenter is offline
post #3 of 7 Old 01-27-2007, 02:41 PM - Thread Starter
has3806's Avatar
But... I thought with HDMI you get Dolby Digital/ DTS/ etc.. all audio + video and need no other cable??? All in one cable solution??
Thx
has3806 is offline
post #4 of 7 Old 01-27-2007, 03:08 PM - Thread Starter
has3806's Avatar
Thx
has3806 is offline
post #5 of 7 Old 01-27-2007, 06:57 PM
ptsenter's Avatar
Well, do you want to say you always get what you're promised?
Besides, it might help to isolate the problem. Maybe your problem has nothing to do with HDMI: receiver might be at fault, DVD player or configuration.
In any case I would try to contact Denon first.
ptsenter is offline
post #6 of 7 Old 01-29-2007, 09:08 AM
TVpOOned's Avatar
ummm....yes. When HDMI promises audio pass through.
I have read a lot about this in another area of the site:
http://www.avsforum.com/avs-vb/showt...&page=38&pp=30
There are problems with some receivers passing through the audio, especially to the rear speakers.
I am still tring to figure it out myself - but yah, the beauty of HDMI is to get everything in one cable, so why would you run it through another cable if you didn;t need to (although that is one solution).
TVpOOned is offline
post #7 of 7 Old 02-02-2007, 11:28 AM
john stephens's Avatar
Quoted: 39 Post(s)
Liked: 40
Originally Posted by has3806 View Post
Hello All,
My connection is:
The 3806 has no problem processing HDMI Audio from a compliant HDMI source. You do have to get up to speed on how to set up the 3806 and or the DVD source. You should also state what brand/model DVD y ou are connecting. I have a 3806 and experience no problems she connecting a Sony BD-p1000, Sony 400 disk changer or a Directv HD PVR.
john stephens is offline
Reply HDMI Q&A - The One Connector World
