Whats the difference between 24AWG and 28AWG HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-31-2007, 01:02 PM - Thread Starter
thelead's Avatar
I can't find any info on the difference. Which is better? and why?
thelead is offline
post #2 of 7 Old 01-31-2007, 03:43 PM
greywolf's Avatar
Location: Evanston IL 60202 11 mi from Chicago transmitters
Smaller numbers mean heavier gauge. Heavier is needed to prevent loss on longer runs. There is a balance between resistance and capacitance the manufacturers work out. Don't worry about it or think one will provide a better picture than another. It's fine to shop for price for lengths under about 15ft. After that, make sure a cable is returnable if there is a problem.
Pat
While I may link to and mention products as examples, I don't recommend specific products.
greywolf is offline
post #3 of 7 Old 11-29-2007, 01:23 PM
Carlp336's Avatar
bump an oldie.
so a 28awg will transmit 1080p @ 6ft ?
Carlp336 is offline
post #4 of 7 Old 11-29-2007, 02:30 PM
eliteconcept's Avatar
yes, its not a question of if it will do it or not. hdmi is rated to do 1080p if preforming and made within hdmi specs. Its more of a question if you will experience signal degradation. Which you won't anything under 15ft is going to get to there without problems. After that you need to take into account the size of the cable.
eliteconcept is offline
post #5 of 7 Old 11-29-2007, 03:59 PM
ccotenj's Avatar
Liked: 101
Originally Posted by Carlp336 View Post
bump an oldie.
sure. i have one doing it 15 ft.
- chris
ccotenj is offline
post #6 of 7 Old 11-30-2007, 06:00 AM
evan1's Avatar
So how would you know if you lost any resolution on longer runs, is there a way to measure it
Almarra 318B-Zu Audio Omen-Marantz SA15S1-Nottingham Analogue Interspace Jr.-BlueSound Node-Schiit Modi Uber-AQ CV4 72v dbs speaker cables-Clarity HarvestII Interconnects-TWL powercords-ATS acoustic panels-Echo Buster corner trap
evan1 is offline
post #7 of 7 Old 12-11-2007, 02:47 PM
ScottyA51's Avatar
You can't 'loose resolution' with digital data. Either all the bits get through, or they don't; if they don't you usually won't get any signal at all. That's why your old analog cell phone used to go all staticy before it dropped entirely, while your spanking new digital one drops the call suddenly with no warning.
ScottyA51 is offline
Reply HDMI Q&A - The One Connector World
