Do I need CL2 cables? - AVS Forum | Home Theater Discussions And Reviews
Old 02-01-2007, 10:22 PM - Thread Starter
G5Unit's Avatar
Do I need to get CL2 certified HDMI and component cables if I want to run them behind the wall?
Here to learn.
G5Unit is offline
Old 02-02-2007, 11:28 AM
Paul_PDX's Avatar
It all depends on your states and counties electrical, fire, and building codes.
Paul_PDX is offline
Old 02-04-2007, 10:25 PM
jwatte's Avatar
It's not just the law, it's a good idea!
The point of fire code wiring is that it doesn't spread a fire from one place to another too easily. If you care about your house being more resistant to burning down, getting CL2 cable is worth it. This is how I figure it:
Percentage = 100 * (House cost / Cable Price Difference)
If the percentage is less than 1, then getting the safer cable is a no-brainer.
jwatte is offline
Old 02-07-2007, 05:50 PM
fedders's Avatar
The simple answer is yes. You may not need CL2 per se, (CMX, CM, CL3, CL2X, CL3X, etc.) may be fine as well (assuming a residential application).
While installing this cable through the wall will likely not need an inspection and nobody will ever come to your house and say you shouldn't do that - I would hate to give the insurance companies any excuse to not reimburse you should there be a fire in your home.
Carl
Carl Fedders
fedders is offline
