HDMI/DVI compatibility - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-18-2007, 03:57 AM - Thread Starter
bsvends1's Avatar
Due to the lack of an appropriate forum section, I'll just post this here.
My set-up:
Toshiba HD-XE1, a Denon 3930, and a Playstation 3.
Cable1: Gefen fiber 10m DVI-DVI w/DVI-HDMI adapter on source end.
Cable2: Kramer fiber 20m HDMI-HDMI w/HDMI-DVI adpter at receiver end.
Toshiba: cable1 - no picture or snow, cable2 - picture
Denon: cable1 - picture, cable2 - blinking picture (on/off)
PS3: cable1 - picture, cable2 - picture
Tried different projectors, same result. Cable2 even has an extra 5V psu, so I find the results here very confusing. Any suggestions?
bsvends1 is offline
post #2 of 7 Old 03-18-2007, 04:36 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3403 Post(s)
Liked: 2658
My set-up:
Try the HDMI forum:
http://www.avsforum.com/avs-vb/forum...ysprune=&f=168
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3 of 7 Old 03-18-2007, 05:03 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 336 Post(s)
Liked: 6992
Moved to HDMI forum.
Was the PS3 used with a Blu-Ray movie? If not, the PS3 may not be using HDCP. Your symptoms are "classic" HDCP handshake issues. This could be caused by cable/connector issues and "quirks" in the HDMI/DVI implementations in the gear.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #4 of 7 Old 03-18-2007, 09:08 AM - Thread Starter
bsvends1's Avatar
As far as I know this issue is not related to HDCP since the picture problems occurs before loading any DVD. The PS3 is the only player here with no issues.
bsvends1 is offline
post #5 of 7 Old 03-18-2007, 09:29 AM
maddogmc's Avatar
Have you tried these equipment combinations with an all copper cable solution?
It would be interesting to know if the electro/optical conversion implementation was flawed on both cables only in different ways.
"I'm a fanatic without a cause and I believe in it!" - B. D. G.
maddogmc is offline
post #6 of 7 Old 03-19-2007, 03:55 PM - Thread Starter
bsvends1's Avatar
Well the HDCP seems to be in effect even without any movies in the players. Anyway, just got a shorter Gefen HDMI-HDMI w/DVI adapter and things work great.
bsvends1 is offline
post #7 of 7 Old 03-21-2007, 03:39 PM
HDMI_Org's Avatar
If a new (shorter) cable fixes the problem, it sounds like your previous cables were marginal. Glad to hear you got things working.
HDMI_Org is offline
Reply HDMI Q&A - The One Connector World
