Monoprice 5x1 HDMI switcher: repeater also? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-19-2007, 09:18 PM - Thread Starter
MacBuster's Avatar
I'm going to be connecting my projector to a Monoprice 5x1 HDMI switch. I need a 50 ft HDMI cable to get from my projector to the switch itself. (My sources into the switch will be a PC, sat receiver and HD-DVD player).
Monoprice recommends using the 50ft HDMI cables with a repeater in...I presume to avoid sparkles, etc.
My question is:
Does the Monoprice 5x1 switch behave as a repeater sufficiently to use the 50ft cable without worry? It says it's an "integrated equalizer" on the product page, but makes no reference to being a "repeater."
Will I be good with this setup?
MacBuster is offline
post #2 of 2 Old 03-20-2007, 10:59 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 327 Post(s)
Liked: 6685
At 50 ft you're playing with fire, especially with 1080p. I see now you can buy (RAM has them) amplified HDMI cables. There's a 20m amplified cable, guaranteed for 1080p, for $265. I'd do something like that or fiber, or cat5, and never worry about length vs resolution vs various differences in xmitters/recvrs again. If you are running cables through walls repeaters can be problematic. They should be "in the middle".
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
Reply HDMI Q&A - The One Connector World
