Running HDMI cables parallel to power lines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-20-2007, 06:46 PM - Thread Starter
Jotsy's Avatar
Just a quick question. would there be any detrimental effects to running HDMI cables along side to power lines? i'm talking about in-wall power lines for a wall outlet, and i'm only talking about a short distance. Probably no more than a 2 meter run. Would i need higher quality cables with some of that fancy shielding (ie, the more expensive ones)?
Jotsy is offline
post #2 of 3 Old 05-20-2007, 07:14 PM
AV Doogie's Avatar
Should not be a problem, however, for safety and identification purposes, it is a good idea to add some distance between power and data cabling.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #3 of 3 Old 05-22-2007, 03:35 PM
HDMI_Org's Avatar
Yes, shouldn't be a problem as HDMI signals are shielded and their differential nature tends to reject outside noise.
HDMI_Org is offline
Reply HDMI Q&A - The One Connector World
