Connecting My HDMI from my Xbox 360 to my TH-42PZ77U, having problems~~!!! - AVS Forum
post #1 of 11 Old 09-28-2007, 02:33 PM - Thread Starter
kevinele7en's Avatar
i recently purcased an hdmi cable and my panasonic plasma, and i am having trouble getting a signal. The bestbuy people told me it should work automatically when i plug it in. dunno why i can't get a picture.. the screen just stays blank. Is it something with the settings of the xbox or tv? because i tried to change those to hdmi, or do u think something is just wrong with my xbox because i can hook my laptop to my tv via dvi to hdmi
kevinele7en is offline
post #2 of 11 Old 09-28-2007, 02:34 PM
emagana02's Avatar
Make sure you select the right source...Either it be input 1, input2 or input3.
HTH
emagana02 is offline
post #3 of 11 Old 09-28-2007, 02:39 PM - Thread Starter
i have it on the right source, like i plug it into hdmi 1, and then i put the tv source to hdmi 1
post #4 of 11 Old 09-28-2007, 05:39 PM
Kei Clark's Avatar
Make sure that your xbox is set to a resolution you know is supported by your TV.
Kei Clark is offline
post #5 of 11 Old 09-29-2007, 01:46 AM - Thread Starter
yea, i set it to 1080p, and put the black level to the best, and then i try to plug in my hdmi to the tv, and nothing shows up
post #6 of 11 Old 09-29-2007, 07:02 PM
Kei Clark's Avatar
Have you tried lower resolutions?
post #7 of 11 Old 10-01-2007, 05:26 AM
Denog's Avatar
I have this TV as well and noticed it takes about 10-15 seconds for the X360 to boot up now. I think it may be how the TV and the X360 are handshaking that is causing the issue.
Denog is offline
post #8 of 11 Old 10-03-2007, 12:27 PM - Thread Starter
i got it to work, turns out something was wrong with the original hdmi cable ih ad, had to get a new one
post #9 of 11 Old 10-03-2007, 04:07 PM
Foxbat121's Avatar
Quoted: 67 Post(s)
Liked: 190
1080p put burden on HDMI cables. I'd only buy HDMI 1.3 Certified Category 2 cable to be sure it works with 1080p. Any cheap cable will work with 1080i but not necessary with 1080p.
Foxbat121 is offline
post #10 of 11 Old 10-08-2007, 07:49 PM
captainfish's Avatar
Good to know. thanks
captainfish is offline
post #11 of 11 Old 10-11-2007, 09:14 AM
Denog's Avatar
Did the one giving you problems come with the Elite? I have the same tv and my startup times are still delayed from the time I power it on to about 15 seconds.
Denog is offline
Reply HDMI Q&A - The One Connector World
User Tag List
