Need help finding a suitable FireWire card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-14-2008, 05:02 AM - Thread Starter
crazzy6983's Avatar
Hi All,
I need some help trying to frin a suitable FireWire card.
What I', after, is a four port FireWire 400 card, where each port has it's own seperate controller. It has to be able to fit into a PCI or PCI-X slot.
This is due to the issues Windows XP has with FireWire (i.e. it doesn't fully support it) when I plug in the devices we use.
Any help would be greatly appreciated.
Regards
Chris
crazzy6983 is offline
post #2 of 2 Old 08-23-2008, 08:54 AM
davais's Avatar
how about Sonnet Allegro 4 Port FireWire 1394A PCI Card? compatible with most Mac and Windows systems with PCI or PCI-X slots,
davais is offline
Reply Firewire 1394 Trade Association Q&A
