Firewire 800 on XP SP2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-27-2008, 07:50 PM - Thread Starter
SmokeWatcher's Avatar
I can't seem to find a clear answer anywhere...
Is it possible to get firewire 800 speeds while running XP Pro SP2?? I'm certain 400 speeds are possible with registry tweaks. Do I need an add-in card to get 800 speeds, or is there simply a limit to what XP will allow?
SmokeWatcher is offline
post #2 of 4 Old 10-28-2008, 01:35 AM
Krobar's Avatar
Quoted: 17 Post(s)
The default drivers damage firewire performance and drop it to 100Mb with an 800Mb device. You need to install a third party driver to fix this, some cards come with the Orangeware driver fo example (Siig's does).
Krobar is offline
post #3 of 4 Old 10-28-2008, 05:34 PM - Thread Starter
Will I be able to get FW800 speed using an add-in card, or will I be limited to 400 simply because it "XP SP2"
post #4 of 4 Old 12-24-2008, 09:21 AM
Krobar's Avatar
Quoted: 17 Post(s)
With the orangeware driver you can get 800Mbit speeds. Unless you are using a PCI-E card or PCI-X firewire card in a PCI-X slot then you will not quite get full 800Mbit performance due to the bottleneck of legacy pci (Realistically most standard PCI busses top out at 600-700mbit and thats assuming the firewire card is the only device using the bus).
Krobar is offline
Reply Firewire 1394 Trade Association Q&A
