Help with firewire card - AVS Forum | Home Theater Discussions And Reviews
Old 12-15-2008, 05:43 PM - Thread Starter
1992lee's Avatar
Can anyone recommend a device with firewire input that can decode an hd signal from a mitsubishi dvhs that can then be displayed on an hdtv through an hdmi output. The hd signal from the mitsubishi hd vcr apparently has to be decoded before it can be displayed, and compatible Mitsubishi tvs typically do this; however, my Mitsubishi tv is dying. No one has been able to help me so far.
1992lee is offline
Old 12-17-2008, 04:34 PM
tkmedia2's Avatar
I don't recall anything that had hdmi except the mitsubishi. LG LST3410A DVR, Samsung SIR-T165 OTA STB, Mitsubishi HD6000 and older HD500. JVC D-VHS decks have decoders. I know I forgetting another one...
EDIT: MIT MDR-200. KeyDigital had one I think.
tkmedia2 is offline
Old 12-18-2008, 07:06 PM - Thread Starter
1992lee's Avatar
Thank you for your response.
1992lee is offline
