Connecting Pioneer-989 to PC over iLink(1394) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-03-2009, 04:30 AM - Thread Starter
mike09's Avatar
I tryed to connect Pio-989 to PC over 1394 in aim of getting PCM-stream during playing SACD. PC wants driver.
Somebody tryed to do that?
mike09 is offline
post #2 of 2 Old 09-24-2009, 09:20 AM
FastEddy23's Avatar
Windows 2K / XP and up should have all the host port drivers for FireWire built in ... Check with MicroSoft for updates, first, then check the motherboard maker for the built in port updates (or the plugin FW port card maker).
The chip set on the motherboard / plug in cards are the key: see who made your FireWire port chip set ... TI, NEC, Agere' / Lucent / VIA ... ??
Anyway, Gates and Company has had several issues about buggie Windows drivers, so getting these straight from the chip set manufacturer will often resolve a number of peculiar issues ...
"Truth is one, paths are many ... " - The Dalai Lama
" FireWire speeds set to quadruple "
FastEddy23 is offline
Reply Firewire 1394 Trade Association Q&A
