FireWire 800 9pin/4pin for MacBook/Denon Receiver - AVS Forum | Home Theater Discussions And Reviews
Old 05-11-2009, 10:15 PM - Thread Starter
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 65
I'm interested in using a MacBook Pro to play high-resolution music files (24/192) into my Denon 4806 receiver. Its DACs will handle that resolution. Denon says that the IEEE1394 port on the receiver should work with the MacBook. I certainly hope they're right!
Does anyone have any experience about using a 9pin FireWire 800 -> 4pin IEEE1394 cable to connect these types of devices?
Lee
GoldenEar Triton One speakers (6, for front, side surround, and rear surround), GoldenEar SuperCenter XXL center channel, GoldenEar HTR7000 overhead speakers (4), JL Audio F113 x 2 (subwoofers), Krell Foundation pre-pro, Krell EV403 (front 3 channels), 2 x Krell S1500/4 (one for each side's 2 surround and 2 overhead speakers), OPPO 105D (Blu-ray, SACD, DVD-A), Calyx Audio DAC24/192, MacMini w/ 2TB drive (server), Purist Audio interconnects & speaker cables, Sony XBR-75Z9D monitor.
RBFC is offline
Old 09-24-2009, 10:04 AM
FastEddy23's Avatar
No problem found ... 9-pin to 4-pin cables will work / connect to both, Apple and Devon. Data transfer rates are plenty fast enough (>40 MegaBytes per second / >400 mbps) ... for 24bit/96k (or higher), multichannel (Dolby 5.x and 7.x) or professional 4 to 16 channel 24bit/96k streaming.
The best 9-pin cables are from Newnex and Unibrain.
Mercenary announcement: both distributed by my company: http://firewirestuff.com/cables.html
"Truth is one, paths are many ... " - The Dalai Lama
" FireWire speeds set to quadruple "
FastEddy23 is offline
Old 10-23-2009, 09:24 PM - Thread Starter
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 65
Thanks for the reply!
We tried this, and the Plasma monitor showed the message "MacBook Not Play". Apparently, the two devices would not handshake, but the Denon did recognize what was hooked up to it.
Thanks for the effort.
Lee
RBFC is offline
Old 10-24-2009, 07:38 PM
FastEddy23's Avatar
"MacBook Not Play" ... Mmmmm
Maybe Devon has a driver or software support for Apple Mac? LG and Panasonic have made monitors for Devon in the past ... might try "selecting" one of those from the MacBook list of monitors supported ... or find a Panasonic driver for Apple OS.
Old 11-06-2009, 08:53 PM - Thread Starter
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 65
I'll check into this with them. Once again, I appreciate the effort.
Lee
RBFC is offline
