Firewire Network? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2009, 07:50 PM - Thread Starter
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
I have a question about firewire connection topologies.
I want to connect equipment in 3 rooms.
Each room will have a 6 port hub.
The following equipment is in each room.
Room1:
JVC 40K DVHS
Sharp LC45GX6U HDTV
PC
Sony Vaio DVD Changer
Room 2:
JVC 40K DVHS
Sharp LC45GX6U HDTV
PC
Motorola DVR
Room 3:
JVC 40K DVHS
PC
I would use 2 sets of Unibrain Firewire->CAT5 extenders to connect the rooms.
I have a couple of questions though.
1. Will this work-Is this OK by Firewire standards-the physical connections/graph/topology
2. Will the DVHS decks be able to communicate from room to room? What about playing back a DTheater title in Room 1 from the deck in Room 3?
3. Will the TV in room 1 be able to use the DVR/DVHS in room 2?
4. Are these Unibrain extenders reliable/bulletproof over 100ft runs?
5. Will the PC's prevent playback of 5C contents by their mere presence on the network graph.
6. How reliable is DVHS/DVR firewire control through the tv's built in firewire control panel.
qz3fwd is offline
post #2 of 3 Old 11-26-2009, 06:27 PM
Kipp Jones's Avatar
1 Should not be a problem even though I would encourage you to utilize 1394 repeaters.
2 Should not be a problem, it is a secure network.
3 Should be able to.
4 Don't know, I like 1394 repeaters and have had sucess with them, let us know how yours works.
5 No but since the PCs are not 5C they will not play back protected content.
6 I have a similar Sharp display and it has worked o.k. for me. I prefer to use the VCR remote directly.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #3 of 3 Old 11-16-2011, 06:35 PM - Thread Starter
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Update.
Unibrain extender did not work for me.
However Newnex FireNex CAT5 repeaters work very nicely interconnecting bedroom/living with 75ft Cat6 cable. I stream HDTV from my Comcast DVR to the bedroom Mac Pro. Devices are connected to Kramer powered hubs-computers, tuners, disc subunits, dvr's, tv's.
My Yamaha DVD-S2500 is flaky though. When powered off, my Sharp tv drops out of the network. While powered on all nodes function properly. All nodes connected to a hub with Firenex repeater connecting rooms.
Cool technology.
qz3fwd is offline
Reply Firewire 1394 Trade Association Q&A
