IEEE-1394 Adapter Help Required - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-16-2009, 03:32 PM - Thread Starter
Mark Jones's Avatar
Greetings..I'm a newbie to this site...I need some help with an adapter question..I have IEEE-1394 (4 pin) coming out of my HS-HD2000U DVCR and wanting to take the signal into a Pioneer PDP-6020 HDTV. To my knowledge, the PDP-6020 has only HDMI or Component inputs for HD inputs...are there any inexpensive adapters available that would do this? Maybe there is another approach? Thanks for any help.
Mark Jones is offline
post #2 of 5 Old 12-18-2009, 10:29 PM
Kipp Jones's Avatar
My solution was the JVC http://support.jvc.com/consumer/prod...3&archive=true 1394 in, HDMI out. Cool and dependable solution. You can find them cheap now days.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #3 of 5 Old 12-18-2009, 10:51 PM
Kipp Jones's Avatar
post #4 of 5 Old 12-06-2011, 11:07 PM
vector357's Avatar
I have the fire wire IEEE 1394 to an adapter for DV input, but for some reason, I can't seem to get a driver so I can connect to my DVR. My main goal is to be able to play netflix video's on my TV. My TV is not HDTV ready, but the DVR has an up converter built in. OK, I may be a little too cheap to get that LCD TV yet, but I still need to figure this out so I can watch movies. Any Ideas or thoughts on what I might be doing wrong?
vector357 is offline
post #5 of 5 Old 12-15-2011, 10:48 PM
hanery's Avatar
There are so many brand like JVC,Belkin available in the market from which you can easily get IEEE-1394 4 pin or 6 pin adapter at low cost between 2$ to 4$. As per my experience I suggest you to buy Belkin F3N401-06-ICE IEEE 1394 4-Pin/6-Pin 400 Mbps FireWire Cable (6 Feet), it provide better performance at low cost compared to other brands.
hanery is offline
Reply Firewire 1394 Trade Association Q&A
