Firewire Active Extension Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-07-2010, 06:18 PM - Thread Starter
Bogey62's Avatar
I already have a 25' Firewire 4-pin to 6-pin cable that I use to hook a camcorder to my computer. I need a longer cable length, but I think my only option now is a Firewire Active Extension cable.
I have seen several cables available online with prices ranging from $20 to $55 for a 14'-16' length.
I have read reviews for one of these cables from CablesToGo that stated that it overheated and burned out!
Is there anything special I should look for in this type of cable or is it just a "buy and hope" operation?
Three of the cables I am considering are:
http://www.mycablemart.com/store/car...t_detail&p=545
http://sewelldirect.com/firewireextension.asp
http://www.datapro.net/products/fire...extension.html
Any advice will be greatly appreciated.
Bill
Bogey62 is offline
post #2 of 6 Old 01-07-2010, 08:45 PM
Kipp Jones's Avatar
Yes, you need the 1394 repeater as a stand alone device or built in to the cable. That will work for you. I have run 100' with the repeaters.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #3 of 6 Old 01-29-2010, 02:12 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
I tried using a repeater myself to connect a DVHS and a TV in seperate rooms.
The repeater doesnt seem to be compatible.
What about using a 33 foot 6 Pin/6 Pin cable into powered hubs/repeaters in each room? This may be my next step. I'll pickup 2 Belkin 6 port hub/repeaters and a 33 foot cable as well as 2 3 foot cables. This setup will likely cost ~$130. If it works, it will be a substantial savings over the unibrain repeaters ($450 for 2 sets), but I dont know if a 33 foot cable connected to these hubs will be sufficient?
Kipp-Any recommendations?
qz3fwd is offline
post #4 of 6 Old 02-06-2010, 09:35 PM
Kipp Jones's Avatar
What exactly are the devices you are trying to connect (DVHS & TV model)?
Kipp
post #5 of 6 Old 02-08-2010, 09:42 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
Sharp LC45GX6U
JVC 40K
JVC 110U
Comcast Motorola DCH3416
qz3fwd is offline
post #6 of 6 Old 02-08-2010, 08:12 PM
Kipp Jones's Avatar
I have a similar Sharp display in 26" and it worked. You may have a sync issue. Have you tried connecting the 1394 link before plugging in the power to your devices? Sometimes it makes adifference.
Kipp
Reply Firewire 1394 Trade Association Q&A
