External 1394 HDD for recording off a 8VSB & QAM tuner equipped TV - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #61 of 90 Old 11-03-2006, 08:59 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
What set?
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #62 of 90 Old 11-03-2006, 11:09 AM
Rudy1's Avatar
Quoted: 1303 Post(s)
Liked: 1874
Originally Posted by dasanih20
Yes the firewire equipped hard disc record (which is what were discussing in this thread). The unit (Toshiba or Indigita) has no other output other then the firewire. What your saying makes no sense. Unless your in the wrong thread....perhaps.
These particular units don't really need anything other than FireWire/iLink ports to transport both audio and video to and from FireWire/iLink-equipped displays. And since FireWire is capable of carrying 5.1 surround sound, one need only use the display's digital audio output to obtain multichannel sound (through a connection to a surround sound receiver). Both my Toshiba and Samsung DLP's work that way, but you may want to check your display's manual to make sure that capability is supported. :)
There are two types of people in this world: People you want to drink with, and people who make you want to drink.
Rudy1 is offline
post #63 of 90 Old 11-04-2006, 02:24 PM
Droddi0's Avatar
Originally Posted by videobruce
What set?
65732
Droddi0 is offline
post #64 of 90 Old 11-07-2006, 05:58 AM
jjost's Avatar
Which Samsung DLP are you using with your Symbio? I have a HL-R5067w with cable card and was considering buying a Symbio (or an RCA DVR2160) for timed/scheduled recordings of HD and scrambled digital programs through the firewire port (D-Net). However, I had heard that Samsung's version of TV Guide Online would not permit it. --John
jjost is offline
post #65 of 90 Old 11-07-2006, 06:14 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
It works with a RCA 2160.................
post #66 of 90 Old 11-07-2006, 08:45 AM
JrCRXHF's Avatar
Originally Posted by nhak
Vividlogic has FW software that can be installed on a WinXP PC or notebook. According to Vividlogic, this software turns your PC/notebook into a DVR. You can both record and play via the Mitsu FW connection. You may also connect your Cable box dvr to this PC. My new Mitsu TV (62628) had a $100 coupon (included with the TV manual) for this software. It brings the price down to $99. They allow a 30 day trial download. I just got my TV and have not had time to try this software yet. When I try I will report here.
I have not been able to make this work with my TV i get a looping error of Vl firebus then under that it says "bus reset storm, bad devices in the network or device connected in loop."
i have tried different ports on the TV and on the computer still can not get it to work right.
Mitsu 65731 DLP 1080p
Harman AV-435
Harman DV-22 DVD
Koolance Water Cooled Computer
Xbox 360 HD-DVD
PS2
JrCRXHF is offline
post #67 of 90 Old 11-07-2006, 09:42 AM
jjost's Avatar
VideoBruce, It does?! That would be great. What type of Samsung do you have, and how do you get it to work with TVGOS? Thanks. --John
jjost is offline
post #68 of 90 Old 11-11-2006, 07:09 AM
HT Nut's Avatar
TV stays off on mine. I do have a question about the 2160. I just got it last night and when I recorded two shows as a trial, the picture has long pixelated "tears" and jitters, and the audio drops out.
Mitsubishi 57831, OTA HD.
The Mitsubishi DVHS works just fine.
Jerry the HT Nut
HT Nut is offline
post #69 of 90 Old 11-11-2006, 10:02 AM
meverly's Avatar
Mine (Toshiba Symbio) does the exact same thing on my 57831. I thought it was the cable, but after buying a new (and better) one, it's still there.
meverly is offline
post #70 of 90 Old 11-11-2006, 03:33 PM
HT Nut's Avatar
Anyone want a 2016 cheap? It is brand new only a few hours on it now.
Jerry the HT Nut
HT Nut is offline
post #71 of 90 Old 11-11-2006, 03:41 PM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
jjost; this years 'S' '88' series.
post #72 of 90 Old 11-12-2006, 10:41 AM
jjost's Avatar
VideoBruce, thanks for the info. Unfortunately, I have last year's R series (a Samsung HL-R5067W). Severals post imply that this series' version of TVGOS won't recognize the DVR2160, and so scheduled recordings aren't possible. I still haven't found anyone with the Rxx67 series who has gotten either the HD2000u, DVR2160 or Symbio to work. --Regards, John
jjost is offline
post #73 of 90 Old 11-12-2006, 11:32 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
That set doesn't have 1394 ports, does it??
post #74 of 90 Old 11-12-2006, 05:58 PM
jjost's Avatar
Videobruce, actually it does one D-Net IEEE 1394 port. --Regards, John
jjost is offline
post #75 of 90 Old 11-13-2006, 07:26 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
Ok, but no TV Guide OS? (Too many models, to many numbers)
post #76 of 90 Old 11-13-2006, 12:34 PM
jjost's Avatar
Videobruce, yes the HL-R5067w does have TV Guide On Screen, though I don't know the firmware version. --Regards, John
jjost is offline
post #77 of 90 Old 11-14-2006, 04:16 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
Again, too many model numbers to keep track of. Even if one just kept track of one manufactures model numbers. :(
Now to answer your question, You should have a separate TV Guide booklet included with the set (unlike that other manufactures DVR that had nothing) that does a decent job of explaining who it works. Just remember those AV-HDDs' are 'dumb' devices, they need something to control it (either you or the TV Guide OS).
Actually, if you have two units you should be able to edit a already recorded program (say commercials or just save certain portions as in a concert) to the other drive.
post #78 of 90 Old 11-14-2006, 06:02 PM
jjost's Avatar
videobruce, I do have the TV Guide booklet, but there is no mention of recording to a firewire device. Recording is described only in terms of recording to a VCR. Do you know what version of TVGOS firmware that you have? Thanks. --John
jjost is offline
post #79 of 90 Old 11-15-2006, 05:17 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
The documentation of TVGOS and 1394 devices is nothing short of terrible.
Probably courtesy of the NCTA as they would rather have you rent their box ($$$). :mad:
If the TV reconizes the AV-HDD device, then that should migrate over to the TV Guide menu when you select 'record' for a program. It will be in the recording device selection on the left panel (forgot what it is called exactly).
Note, these 1394 devices will only record ATSC/QAM channels, NO analog!
Actually, even though my last post was generic to any set with 1394, this thread was suppose to be for Mits sets. Don't want to get the Mits boys mad.............
post #80 of 90 Old 11-15-2006, 06:25 AM
jjost's Avatar
videobruce, thank you for your help. I agree that the TVGOS documentation is atrocious. I'm just trying to figure out which of the Mits HD2000u and the RCA DVR2160 works with my Samsung HL-R5067w. I'm mainly interested in being able to schedule recordings, but I have read conflicting posts as to whether the version of TVGOS on my Samsung model (or the Rxx67 series in general) would permit this with either product. Unfortunately, I do not have the financial wherewithal to just buy one from eBay and try it out. So, I've been looking for someone who has the same model series and who has gotten one of these to work. Again, thanks for your help. --John
jjost is offline
post #81 of 90 Old 11-15-2006, 07:23 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
Try here;
http://www.vgi.com/support/
and here;
http://www.avsforum.com/avs-vb/showthread.php?t=537675
post #82 of 90 Old 11-16-2006, 06:23 AM
jjost's Avatar
Videobruce, I had already checked both links and couldn't find a definite answer, but thanks for the suggestion. --John
jjost is offline
post #83 of 90 Old 11-21-2006, 04:50 PM
bwall23's Avatar
I know this is a Mits thread and I have a Mits, but have you tried calling 1-800-726-7864 (Samsung)
bwall23 is offline
post #84 of 90 Old 11-22-2006, 05:02 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
I have talked with 2nd level Samsung support and he (talked to the same guy both times) hasn't tested AV-HDD devices with those sets. They are products that Samsung doesn't sell. I had a similar experiance with Mits and they sell a AV-HDD.
post #85 of 90 Old 11-22-2006, 06:07 PM
bwall23's Avatar
That number is what's listed on the TV Guide On Screen website for Samsung support for TVGOS
bwall23 is offline
post #86 of 90 Old 11-25-2006, 12:34 AM
hd nOOb's Avatar
Has anyone been able to send info ( HD CONTENT ) to this drive from windows xp?
I would just like to view HD STuff on my WD-Y57
Thx
Blu ray is the best Blah, blah, blah.
hd nOOb is offline
post #87 of 90 Old 11-25-2006, 06:25 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
What's a "WD-Y57"?? Is that a step up from a WD-40? :D
post #88 of 90 Old 11-25-2006, 06:30 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
Samsung 5088 (any xx88 or the 5679):
I finally got around to actually trying to record something on my two 2160s' but to my dismay (putting it mildly), while it appeared to record something, when I played it back there was nothing. There were three different programs, on two different channels (through cable) all in the clear (network) and with an entry showing in the play list and it showed occupying space on the HDD, the screen was blank with no audio.
I took the AV-HDD to my other set (HP/Sharp LCD flat panel) where it was used originally and tried to play back those programs and still nothing. I then made some test recordings on a couple of channels and they played back ok (as before).
Then I reconnected that deck back to the Sammy and those recordings that were made on the HP played back ok. I tried to make another recording (manually) from the Samsung and nothing.
Mind you, these playback entries do show and there is a size and time associated with them. Also, these are just network programs that show as "copy free". I have unplugged the set for 15 minutes and tried again, but still nothing.
Any ideas??
post #89 of 90 Old 11-26-2006, 09:55 AM
hd nOOb's Avatar
The WD-Y57 Is Circuit City 732 model Mits DLP.
I have my hard drive formated in NTFS do I need to reformat in FAT 32 to make my comp see the Scenium 2080 AVHDD drive?
hd nOOb is offline
post #90 of 90 Old 11-27-2006, 08:12 AM - Thread Starter
videobruce's Avatar
Quoted: 658 Post(s)
Liked: 254
That's their fictious model number. :mad: Is this it??;
http://www.mitsubishi-tv.com/j/i/183...s.html?cid=387
Are you talking about removing the HDD from the RCA and installing it in your computer?
Closed Thread Firewire 1394 Trade Association Q&A
