Indigita AVHD IEEE 1394 Hard Disc Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 616 Old 11-11-2005, 10:00 PM - Thread Starter
Kipp K.'s Avatar
Hello,
New to this forum, I did a search on the above but was not able to find much on it. I know my Mitsubishi dealer uses one to show the 1080p demo loop on his new TV's. He received this from Mitsubishi. I was able to borrow one and it worked great on my set. I have a copy of the manual and pictures of it inside and out if anyone is interested.
Indigita AVHD IEEE 1394 hard disc drive
I was hoping someone else might have one and could tell how well it works for recording?
thanks,
Kipp
Mits 1080p DLP WD-52628
Mits WT-46809
Dish HD DVR 942
Sony DVP-NS70H
Kipp K. is offline
post #2 of 616 Old 11-12-2005, 07:38 AM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
a few key points from the literature that make me think the public won''t easily get them, unless a major mfg offers the in their branded product line:
A fully customized FireWire DVR solution for OEMs
Private labeling and individually optimized software
The AVHD Powered by Indigita is a custom digital PVR/DVR solution for consumer electronics (CE) and set-top box (STB) original equipment manufacturers (OEMs).
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #3 of 616 Old 11-12-2005, 10:33 AM
HDTVFanAtic's Avatar
I saw a Mitsubishi 1080p set at Fry's in LA last week showing 1080p material. I had wondered what they were using as the rest of the sets were on HDNET via Dish, but I did not follow the wires as I didn't have the time.
After your research, I am sure that is what they must have been using.
HDTVFanAtic is offline
post #4 of 616 Old 11-12-2005, 10:55 AM
Phloyd's Avatar
Fry's in Sunnyvale are most certainly using one of these on their Mitsi display.
The Samsung 1080p DLP TVs are using a Samsung AVDisk, so that one might be easy to get hold of...???
Cheers!
Phloyd is offline
post #5 of 616 Old 11-13-2005, 12:01 PM - Thread Starter
Kipp K.'s Avatar
You're absolutely right, it makes it sound like they are just for OEM, but a fellow poster on the Mits forum, states that he has bought a couple of them, and has also given me the contact name and number, I plan on contacting the person tomorrow and get the specifics.
Kipp
Mits WT-46809
Dish HD DVR 942
Sony DVP-NS70H
Kipp K. is offline
post #6 of 616 Old 11-13-2005, 09:01 PM
CKNA's Avatar
Originally Posted by Kipp K. View Post
Hello,
thanks,
Kipp
This thing looks similar to Toshiba Symbio AVHDD. Toshiba states that it only works with their TV's but it is not true. It works with most firewire equiped TV's that have AV control.
CKNA is offline
post #7 of 616 Old 11-13-2005, 10:21 PM - Thread Starter
Kipp K.'s Avatar
Do you have one?? If you are not using it on a Toshiba, what are you using it on?
thanks,
Kipp
Mits WT-46809
Dish HD DVR 942
Sony DVP-NS70H
Kipp K. is offline
post #8 of 616 Old 11-14-2005, 02:03 AM
Techtom's Avatar
Hello,
thanks,
Kipp
The RCA DVR10 is the same thing... Find one on ebay.
Techtom
Techtom is offline
post #9 of 616 Old 11-14-2005, 02:08 PM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Tom,
Just got an RCA DVR10, but it's a demo unit..I'll have to see if it has "special" firmware that only let's it play and not record..also want to see what my XP pc "sees" when I connect it up.
Also interested in what kipp finds..
Bob
post #10 of 616 Old 11-14-2005, 02:59 PM - Thread Starter
Kipp K.'s Avatar
Tom,
I did get a hold of Chris at Indigita, he was able to give me some more info as well as an email address, so I can ask some more questions.
Prices are as follows:
250 Gb 499.00
160 GB 399.00
It cannot hook up to a computer apparently. Although I know that the ones the Mits dealers are getting come with the content already on the hardrive, (they had to get it on there somehow)
It does support 4 streams of video, so you can be recording one thing, watching something else on one TV, and then another, etc.
I have scanned a copy of the manual, and have screenshots of the unit, inside and out.
Well that is all I have for now....
Kipp
Mits WT-46809
Dish HD DVR 942
Sony DVP-NS70H
Kipp K. is offline
post #11 of 616 Old 11-14-2005, 03:21 PM
locomo's Avatar
Quoted: 43 Post(s)
Liked: 31
Techtom
What's the difference between that and a RCA DVR2160?
I just received one fairly cheap, but I can't get it to record
off a firewire equipped Scientific Atlantic 3250hd.
locomo is offline
post #12 of 616 Old 11-14-2005, 04:41 PM - Thread Starter
Kipp K.'s Avatar
Tom,
I can get a Indigita for fairly cheap, its one of the Mits dealerships units with only a 40 Gb hardrive, but if I can't hook it up to my computer, then I really don't have anyway to put 1080p source on it...this is what I would like to do and then feed it into my 1080p mits TV. I was also wondering if I put a larger hard drive in it, if it would reformat the drive correctly and still work.
Kipp
Mits WT-46809
Dish HD DVR 942
Sony DVP-NS70H
Kipp K. is offline
post #13 of 616 Old 11-14-2005, 06:13 PM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
I have teh same questions..need to play with the DVR10 the next day or so..
Bob
post #14 of 616 Old 11-15-2005, 07:34 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Maybe this might be why.........
I was going to start another thread on this, but I will continue what was started. I have come across some interesting info on this.
First a list of the supported sets,
2nd, specs on this base unit'
3rd, intro on these;
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #15 of 616 Old 11-15-2005, 07:36 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
What this looks like. Notice the lack on make and model on the front. Also notice "DVR 10" on the rear panel;
post #16 of 616 Old 11-15-2005, 07:38 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
For the meat and potatoes. Unfortunately, the pic of the 'important part' doesn't show the chipset. I will see if I can get a better pic. Not a whole lot there w/o the HDD;
post #17 of 616 Old 11-15-2005, 07:43 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The few posts are pages from the users manual.
Generic 1394 connection info. If you have a device that used 1394, you rpobably have seen this before;
post #18 of 616 Old 11-15-2005, 07:45 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Status LED's & troubleshooting;
post #19 of 616 Old 11-15-2005, 07:46 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The next attachments seem to be addressed for the Mits sets with Net Command, but could apply for the other manufactures as well;
post #20 of 616 Old 11-15-2005, 07:47 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
more transport functions;
post #21 of 616 Old 11-15-2005, 08:26 AM
Yaamon's Avatar
If the Toshiba Symbio can be used with other tv then that unit to me sounds like a better deal. 160G Hard drive for $250.00.
http://www.bizrate.com/marketplace/s...269646578.html
F room: Jvc70FH96/8300HDPvr & Dish 811, Bed.room Toshiba 50HM66, & Sa3250, Study LG42PX4D & XBox360: Kids tv: Toshiba 50H81, LG4200a, XBox 360, CM4228, 9521rotor, & 7775 preamp.
Yaamon is offline
post #22 of 616 Old 11-15-2005, 08:35 AM
jumpinjoe's Avatar
Bruce,
Thanks for posting the link on th Toshiba forum. This device looks cool and I have seen the 1080p content at my local AV shop playing on the Mits.
So I guess it is true that 1080p can be played on most new DLP's but the question is how do you get it on there? There has to be a way if it got on their in the first place.
I wonder if it's on the actual HD or maybe could it be in the firmware???
Regarding the Toshiba product; will this also play 1080p content?
I'll contact them to find out.
jumpinjoe is offline
post #23 of 616 Old 11-15-2005, 08:47 AM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Brue, how do you easily get the cover off..what model hard drive do you have in there..??
Bob
post #24 of 616 Old 11-15-2005, 08:49 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Those prices that Kipp received are way out of line. Give me a bare chassis and I will supply the drive.
What we need is someone with that device to open it up and take a pic of the chipset to see who makes it.
I don't have this. It appears just screws on the rear panel.
post #25 of 616 Old 11-15-2005, 08:57 AM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Took all the screws out, the cover didn't want to slide off easily..I'll be glad to do
that if I can get the cover off..
Bob
post #26 of 616 Old 11-15-2005, 09:05 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Try lifting up from the rear.
Next, locate prybar..........
post #27 of 616 Old 11-15-2005, 04:23 PM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Well.. the DVR10 and my Mits 62725 just don't get along..some of the pre-recorded material on the drive would play, but it wouldn't record due to having a conflict with recorded material..so I deleted all on the drive, but it still shows that
it has 6 hours and 35 minutes stored. if I schedule a record, it will go into record for about 30 seconds and then drop out.
Off to play more now..
Bob
post #28 of 616 Old 11-15-2005, 04:58 PM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Now the mits won't even see the dvr10..me thinks the mits needs a powercycle..
If were a consumer who had spent his own money, rather than an engineer who was seeing how well this works, I'd be highly annoyed about now..
Bob
post #29 of 616 Old 11-15-2005, 05:18 PM
bdfox18doe's Avatar
Quoted: 200 Post(s)
Liked: 111
Cover had adhesive putty sticking cover to hard drive mount..this one is internally different from the pictures..drive is maxtor diamondmax16.. 80 gb ata133..
large chip has heatsink glued on..u3 is agere fw802a
Bob
post #30 of 616 Old 11-15-2005, 06:29 PM
Bmr4life's Avatar
Thats a lot. Glad I got one of these when they were $126 shipped on Nov 8th.
Two questions:
Anyone know how to hook up a Dvr2160 so I can send the recorded shows to my computer?
Also, how do I install a larger HDD into a Dvr2160?
thanks
Bmr4life is offline
Reply Firewire 1394 Trade Association Q&A
