Motherboard IEEE-1394 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-14-2006, 09:47 AM - Thread Starter
makryger's Avatar
Does anyone know how to determine whether a motherboard has an on-board 1394 Header? Often, when I see specification for Firewire, it is talking about a connector on the back panel.
makryger is offline
post #2 of 3 Old 10-14-2006, 02:56 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Yes, look at the images they usually have of the motherboard. Newegg posts images where you can see the header(s). Also look at the specifications, they usually spec out the number of ports. Count the number on the backplane and subtract the total.
qz3fwd is offline
post #3 of 3 Old 10-14-2006, 05:02 PM
ginnal's Avatar
Search for it on newegg using the power search option.
AMD Compatible Motherboards with 1394
http://www.newegg.com/Product/Produc...ue=749%3A22088
Intel compatible motherboards with 1394
http://www.newegg.com/Product/Produc...ue=749%3A22087
ginnal is offline
Closed Thread Firewire 1394 Trade Association Q&A
