How to record via 1394 from PC to D-VHS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-15-2007, 12:36 AM - Thread Starter
dannycaphy's Avatar
Dear all:
I have a problem about how to record via 1394 from PC by D-VHS?
Could somebody tell me?
dannycaphy is offline
post #2 of 6 Old 03-15-2007, 02:01 AM
timecop's Avatar
1) TSReader, play a stream and use 'Record program to DVHS' menu option
2) CapDVHS, use 'wrtdvhs' option
3) DVHSTool (anyone use that anymore?), has a way to write ts to DVHS.
timecop is offline
post #3 of 6 Old 03-15-2007, 08:11 AM - Thread Starter
dannycaphy's Avatar
I connect D-VHS and PC via 1394 and use wrtdvhs's option of CapDVHS
then start but TV shows that can not decode video or audio ......
what's problem with that?
Is there special requirements from my computer ?
post #4 of 6 Old 03-15-2007, 03:57 PM
timecop's Avatar
Hopefully you are not sending your TV H264 transport stream files.
timecop is offline
post #5 of 6 Old 03-16-2007, 03:24 PM
Erik Garci's Avatar
GraphEdit is another tool you can use. See this document for details:
Windows XP and D-VHS Howto
(This is a link to the copy at webarchive.org, since the original at webtc.com is down.)
Erik Garci is offline
post #6 of 6 Old 03-26-2007, 09:07 PM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 107 Post(s)
Liked: 69
If the show is 5C it will not be detected by a DVHS emulator only a DVHS machine ( I think
42" in the dining room.50" in the bedroom 80" in the living room 65" in the family room 70" in the family room 106" in the family room "There is another system" Video Modes: SDTV-EDTV-XGA-HDTV-4K
Star56 is offline
Reply Firewire 1394 Trade Association Q&A
