Welcome to the 1394 Fireware area! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-26-2007, 10:14 AM - Thread Starter
David Bott's Avatar
Liked: 45
Welcome to the new 1394/Firewire area. This area is for the chat on 1394 and it is monitored by and responded to by the 1394 Trade Association. What, where, how, why, issues, etc about 1394 and the format can be found here. NOTE...WE WILL NOT ALLOW FOR THE OUTRIGHT ATTACKS OF OUR GUESTS.
Thank you.
David Bott
Founder - AVSForum
DISCLAIMER: All spelling and grammatical errors done on purpose for the proofreadingly challenged...:)
David Bott is offline
post #2 of 6 Old 03-26-2007, 10:19 AM
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
Awesome! This will be very helpful.
Thanks, David!
Kyser
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is offline
post #3 of 6 Old 03-26-2007, 05:55 PM
Kipp Jones's Avatar
Thanks David!!!
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #4 of 6 Old 04-05-2007, 10:24 AM
CharterJames's Avatar
Good Afternoon,
I've got a customer trying to connect some equipment using the IEEE 1394 using a Motorola DCT 6200 series. He's not getting any signal and I was wondering if anyone out there as some notes from the industry side of things I can check and test.
As far as I know it should be enabled from the controler and I'd love to verify this using my IEEE 1394 port on my PC at home, however I've never gotten around to it in the past.
You can reach me directly at my email address, just take my first and last name from my signature and email to first.last@chartercom.com
Thanks for any advice!
Views & opinions stated here are strictly those of Me and not Charter Communications.
I no longer work in Tech Ops as such I can only advise & suggest.
CharterJames is offline
post #5 of 6 Old 04-05-2007, 12:52 PM
FriarWyer's Avatar
Originally Posted by CharterJames View Post
Good Afternoon,
Not sure about using a PC, but with a Mac, your best bet would be to run AVCBrowser from FireWire SDK 23 (developer.apple.com/sdk). This app detects all devices on the 1394 bus that support the AV/C protocol, and allows you to test various AV/C commands and plug connections with the detected devices.
In addition, the FireWire SDK application AVCVideoCap can be used to capture in-the-clear streams from a STB. The GUI for AVCVideoCap shows the EMI (encrpytion mode indicator) for incoming streams. If it shows "copy once" or "copy never", then the stream is encrypted, and won't be usable. If it shows "copy freely", then AVCVideoCap should record a valid stream from the STB.
Hope that helps.
Andy
FriarWyer is offline
post #6 of 6 Old 04-05-2007, 05:29 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3572 Post(s)
Liked: 4650
Check the Motorola DCT series cable box article at Wikipedia.org for model and software/firmware information. I suspect the 1394 port on your customer's Motorola box is not enabled by the software/firmware the cable company has installed in the box.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Reply Firewire 1394 Trade Association Q&A
