Pioneer Plasma & CinemaVU DVR via 1394 - AVS Forum | Home Theater Discussions And Reviews
Old 04-03-2007, 10:37 AM - Thread Starter
Kev639's Avatar
Hi all,
I have a pioneer elite pro-930 plasma that I am using with the built in QAM tuner for my local HD networks - I have been looking for a DVR to record HD and found a thread that mentioned the CinemaVU firewire DVR's. Has anyone tried this combo??? I would like to know a few things before buying one.
1. Does this combo work at all?
2. If it works can you watch a video input on the TV while it is recording off the QAM tuner
3. Does it integrate with the TVGOS for recording
Appreciate the help
Kev
Kev639 is offline
Old 06-09-2007, 06:51 PM
bwall23's Avatar
Originally Posted by Kev639 View Post
Hi all,
Appreciate the help
Kev
I see nobody has replied. You might have a better chance if you post in a thread related to your specific TV model.
1) I can tell you I'm using one on my 2006 Mits TV and it works.
2) Depends on your set and if it has dual tuners. On my Mits set, I cannot since it only has one integrated tuner.
3) It does on my Mits.
bwall23 is offline
