iLink to ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-16-2007, 09:17 PM - Thread Starter
Gary16's Avatar
Quoted: 40 Post(s)
I have a universal player that will only output multichannel audio from an SACD via an iLink output. I do not have any equipment with an iLink input and manufacturers of equipment I own that I've spoken to do not seem to think this will be coming.
What I need is something that will take the iLink output from the player and convert it either to 5.1 digital audio (via HDMI) or 5.1 analog audio much the same as I get from my HD-DVD and BluRay players. Does this exist or will it anytime soon?
Gary16 is online now
post #2 of 6 Old 12-29-2007, 10:56 PM
unbiased's Avatar
Any luck finding an answer? I have a similar situation where I have an older Sony 34XBR2 CRT HDTV with only an ilink connector for its digital connection. I recently upgraded my receiver to an Onkyo NR-905 with hdmi 1.3 connectors and a Samsung BD-UP5000 with HDMI output. Would like to know if there is a way to convert or adapt the HDMI output of the player to the iLink input of the Sony 34XBR2 display? Anyone?
Words of wisdom, "The more you know, the more you know that you don't know."
unbiased is offline
post #3 of 6 Old 12-30-2007, 06:26 AM
frank33411's Avatar
Seems that all the new AV receivers have dropped the ilink connection. I have a Marantz DVD9600 and the new receivers have HDMI 1.3 Things change to quickly and we get stuck upgrading.
frank33411 is offline
post #4 of 6 Old 12-31-2007, 07:00 AM
Krobar's Avatar
Quoted: 17 Post(s)
The new Pioneer SC-lX90 flagship amp has HDMI1.3 and ILink but it is $6000 (Then again is an excellent unit and the Marantz 9600 is not cheap).
Krobar is offline
post #5 of 6 Old 01-01-2008, 12:13 PM - Thread Starter
Gary16's Avatar
Quoted: 40 Post(s)
My universal player is an Esoteric that retails for just under 10K and is a new model which is why I was surprised to find the ilink output as the only was to get the multichannel audio. Someone, somewhere, must make an adapter!!
post #6 of 6 Old 01-02-2008, 04:11 PM
Krobar's Avatar
Quoted: 17 Post(s)
ILink is better for SACD, DVD-A and CD. The Esoterics user Flow Control which reduces jitter significantly (Ilink with flow control has lower jitter than SPDIF which has lower jitter than HDMI).
If you have the budget I would defnitely try the Esoteric with the new Pioneer (Should be completely compatible). Teac chose ILink for a reason.
Krobar is offline
Reply Firewire 1394 Trade Association Q&A
