BD-UP5000 problem discs - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1308 Old 04-04-2009, 07:42 PM
rbouch8828's Avatar
Just watched Slomdog Millionaire this evening and I had two problems with it. When I reached the menu the first time, it refused to Play when I hit Play on the remote. I ejected the disc and then advanced to the menu again and this time Play started the movie.
When I reached the end of the film, it locked on a partial frame of the Menu and would not do anything-No Play, No Eject. I had to shut down the player and then turn it back on at which point I was able to eject the disc.
rbouch8828 is offline
post #632 of 1308 Old 04-04-2009, 07:43 PM
rbouch8828's Avatar
I am running version 1.3.
post #633 of 1308 Old 04-04-2009, 07:53 PM
shawnmos's Avatar
You need 1.4
shawnmos is offline
post #634 of 1308 Old 04-04-2009, 07:55 PM
rbouch8828's Avatar
Originally Posted by shawnmos View Post
You need 1.4
With all the complaints on 1.4 I had decided to stay with 1.3.
post #635 of 1308 Old 04-04-2009, 08:03 PM - Thread Starter
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
It's not as bad as some would have you believe. This is coming from an owner with two BD-UP5000s, 1.4 loaded on both.
vinnie97 is offline
post #636 of 1308 Old 04-04-2009, 08:10 PM
laserjock II's Avatar
Quoted: 715 Post(s)
Liked: 387
Watched it all the way through with 1.4 and no problems whatsoever
laserjock II is online now
post #637 of 1308 Old 04-04-2009, 10:48 PM
HD 335's Avatar
No problem with Slumdog Millionaire either, running 1.4 also.
HD 335 is offline
post #638 of 1308 Old 04-04-2009, 11:16 PM
shawnmos's Avatar
Then don't complain when movies don't work. I have been running 1.4 since the day it came out and have no problems and all of the latest movies work.
shawnmos is offline
post #639 of 1308 Old 04-05-2009, 06:40 PM
A.Bell's Avatar
Quoted: 102 Post(s)
Liked: 74
No problems here either with 1.4
A.Bell is offline
post #640 of 1308 Old 04-05-2009, 10:51 PM
Lordoftherings's Avatar
I second that.
Lordoftherings is offline
post #641 of 1308 Old 04-06-2009, 05:05 AM
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
both of 5K's have been solid performers on firmware v1.4. I only wish that they could play AVC HD content from my new camcorder!
SpenceJT
"Someone ever tries to kill you, you try to kill 'em right back!"
- Malcolm Reynolds, Capt. "Serenity" -
SpenceJT is offline
post #642 of 1308 Old 04-06-2009, 12:53 PM
The Oppo BDP-83 does.
post #643 of 1308 Old 04-06-2009, 12:58 PM
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
Cool! I will check this out!
SpenceJT
SpenceJT is offline
post #644 of 1308 Old 04-06-2009, 11:40 PM
You already knew that Spence!
Did you see "Bolt" yet on blu-ray?
Bob
post #645 of 1308 Old 04-07-2009, 04:52 AM
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
Bob
I have popped Bolt in on my 36" screen for my daughter, but haven't made the time to play it in my HT on the old 65" Mits. Hopefully this weekend.
SpenceJT
SpenceJT is offline
post #646 of 1308 Old 04-07-2009, 10:51 PM
Great animation flick with amazing picture and a little puppy that can unleash some serious damage to your house's foundation! Just be careful with that dial.
Bob
post #647 of 1308 Old 04-08-2009, 10:46 PM
mariogelman's Avatar
Mine (latest firmware) played everything I have tried but Australia(N. Kidman) which froze about 50 minutes before the end. I even tried a different disc, and same thing in the same spot. I called Samsung and they told me they were not aware of this issue. They asked me to reset the player, so I did it but I had already returned the movie to Blockbuster......
Now, I just rented the brand new DOUBT, and it does not play at all. Th disc spins endlessly, then I get a message from the disc stating that I better upgrade the firmware of the player to the latest and that some players take 2 to 3 minutes to load the disc. Well, mine never did.....
Have you experienced the same issue?
mariogelman is offline
post #648 of 1308 Old 04-09-2009, 02:46 PM
transendance's Avatar
I just got off the phone with a samsung rep.
(my unit also will not load "Slumdog", even though I upgraded to 1.4 firmware).
I was informed that latter generation units will play this disc with current firmware,
while older units will have to wait for the next firmware release, it seems that newer
units have some built in features (either hardware and/or software that enable this)!
Care to comment!?~
transendance is offline
post #649 of 1308 Old 04-09-2009, 04:05 PM
Seems like we'll have to wait for a new firmware version (hopefully).
(May is coming fast indeed.)
Bob
post #650 of 1308 Old 04-09-2009, 04:37 PM
360_4_EVER!'s Avatar
Now that's interesting. I've been following this forum for about a year now, and that's the first I've heard that little tidbit. Wonder what the difference could be, and what qualifies as "later generation" on a machine that was only manufactured, what, a year?
360_4_EVER! is offline
post #651 of 1308 Old 04-09-2009, 04:39 PM - Thread Starter
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Smells like BS to me. They likely meant newer player models.
vinnie97 is offline
post #652 of 1308 Old 04-09-2009, 05:25 PM
shawnmos's Avatar
I have to agree.
shawnmos is offline
post #653 of 1308 Old 04-09-2009, 07:36 PM
I just tried the brand new Seven Pounds until minute 38.57....... The movie froze, just like Australia did.......
I made sure the disc was clean, reset the player once again and it froze in the same spot.
V 1.4 is outdated......
I wonder if any of you have v 1.3 available, I would like to downgrade and see....
post #654 of 1308 Old 04-09-2009, 11:26 PM - Thread Starter
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Just rented 7 Pounds for a quick run-through. Played straight through without a hiccup with 1.4. I recommend clearing the flash memory...if that fails to resolve, reset to factory condition (by holding the fast forward button on the unit without any disc in tray).
vinnie97 is offline
post #655 of 1308 Old 04-10-2009, 02:12 AM
Vinnie, I performed the reset fix but same thing it froze at the same spot.....
By the way did you watch Australia ( N. Kidman) on Bluray? it froze about 40 minutes before the end.
In addition to that Doubt did not load at all.......
How to clear the flash memory?
Do you have firmware 1.3 handy? just in case.
post #656 of 1308 Old 04-10-2009, 03:26 AM
Never mind. I reset th eplayer once again, then I unplugged it, held the power button for 20 seconds, plugged it back, tried the movie and same thing, it froze on the same spot.
Finally, I installed firmware 1.4 once again on top of 1.4 and same thing......
I was even able to skip chapters after the freezing incident (38.57), however they don't run, they look frozen as well.....
Haven't been able to finf formware 1.3 yet....
post #657 of 1308 Old 04-10-2009, 06:21 AM
shawnmos's Avatar
bad disc
shawnmos is offline
post #658 of 1308 Old 04-10-2009, 09:58 AM
Shawnpoint, were you able to watch Seven Pounds?
I do not think it is the disc, something similar happened with Australia. I even swap the bluray disc, and same thing.
post #659 of 1308 Old 04-10-2009, 10:43 AM - Thread Starter
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I'll look into Australia and Doubt next. Your player could be overheating...or perhaps needs a cleaning.
vinnie97 is offline
post #660 of 1308 Old 04-10-2009, 11:32 AM
Smarty-pants's Avatar
Quoted: 748 Post(s)
Liked: 627
vinnie, were you the one who said my player was overheating when I stated that the was freezing up on movies?
I had taken it apart and given it a good cleaning and lube job. It played perfect for a while, that started doing it again.
I have the player in an open shelf / tv stand, but the back is closed up. The player barely fits on the shelf, with just enough room for about an inch or less of margin between the player and the front of the shelf. I pulled the player all the way out to the front of the shelf to give a pinch more breathing room to the back of the player.
All seems to be working well again so far.
What was the fan mod thingy mentioned? Where can I find that info?
THANKS
Smarty-pants is offline
Reply Dual Format Players
