LG BH200: Mini-FAQ + Firmware Info (TrueHD 7.1, DTS-HD, 24p) + SD DVD Multiregion! - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2821 of 2843 Old 01-04-2015, 05:06 PM - Thread Starter
bradavon's Avatar
Originally Posted by markjdye View Post
I need the April 2008 firmware for my LG BH200 and I have been unable to find it anywhere. Do you still have a copy? Mark.
Have a look in the first post of this Mini-FAQ thread, then under:
- Miscellaneous - Firmware
Then:
Where do I find older Firmware?
You will see it shown in red there. I can confirm the download link still works.
p.s. - After all these years my LG BH200 is still going strong. I've still only ever had two problem discs too (one was a HD-DVD and one was even a DVD).
bradavon is offline
post #2822 of 2843 Old 02-12-2015, 07:17 PM
Dianabol5mg's Avatar
Quoted: 170 Post(s)
Liked: 124
Hey, brad i'm having some problems viewing any hddvd. I have the player set to region B for my overseas stuff, but I thought that wasnt an issue because hddvds are region free. But even though, when I am in region A I still have issues. Im on the last firmware. Should I go back to an earlier version?
Samsung 60F8500
Samsung 51F8500
LG 55EG9100(killed)
LG 55LHX(un-retired)
LG BH200
OPPO 103D
Dianabol5mg is offline
post #2823 of 2843 Old 04-06-2015, 08:10 AM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
Mine doesn't read HDDVDS OR SD Dvds anymore.... it works fine for BD, but is a turtle of course.
I just updated, have gone through a few FW updates, even going back a ways.
The fact that it will no longer read standard DVDS is confusing me.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is online now
post #2824 of 2843 Old 04-06-2015, 09:25 AM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
Took the drive out and cleaned the heads manually, and it now plays DVDS no problem.
Still doesn't play HDDVDs though.
I can hear the drive searching, but it takes awhile, and then says Disk Error and opens the tray.
I've tried the unplug power/Hold button, I've cleared and initialized...
Not sure what I can try next, I just updated it again, so I know it has the latest.
muzz is online now
post #2825 of 2843 Old 04-06-2015, 10:14 AM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
Thumbs up
Update:
BH200 is back in business 100%!
I shut it off, grabbed an old Maxell DVD lens cleaner, turned it back on, ran the cleaner and tried a few discs.
ALL of them work now......not sure what happened, but I'm not complaining!
tripleM likes this.
muzz is online now
post #2826 of 2843 Old 04-06-2015, 10:22 AM
microbob's Avatar
Quoted: 31 Post(s)
Liked: 24
I just purchased my second BH 200 on EBay for 120.00 after my first one died. I was getting the please wait and nothing would open which is a symptom of a bad mainboard. I'm keeping the old drive incase I need to replace it. Good to know you got everything playing properly again.
Robert
microbob is offline
post #2827 of 2843 Old 04-06-2015, 03:11 PM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
Yeah, good idea.
Pretty happy the BH200 is back in business, I always liked this machine, so I was a lil bummed that I had to ad the Tosh A2 to the rack just to play DVDS/HDDVDs.
The A2 is staying in the rack for awhile to make sure the 200 doesn't start acting up.
muzz is online now
post #2828 of 2843 Old 04-09-2015, 02:48 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Originally Posted by muzz View Post
Yeah, good idea.
You happened to do all the things I was going to suggest. Use a lens cleaner. I have found the Maxell that has the wind tunnel affect works well and also I have a couple with brute force ones with brushes. Two different Dishwasher versions and a Bib one that has what looks like many small paint brushes. All of them have had various results. I revived my A35 with the Bib cleaner years ago. For some reason it decided not to play some HD discs and after that it has been fine. The next step after that is the manual cleaning, which in your case SHOULD have revived both DVD and HD. Perhaps it just needed a swift kick in the pants.
Our BH200 is also running great. It has not had much use but the boss did watch Big Hero 6 over the weekend with no issues. I only own the one, but I own 6 working Samsung BD-UP5000s and parts enough to make a 7th. Overall I think the BH200 is a better machine but for some reason I globbed onto the 5ks.
mr.kludge is offline
post #2829 of 2843 Old 04-09-2015, 04:00 PM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
May have been coincidence with the Maxell cleaning, maybe the lens wasn't dry enough, or maybe there was a little film on it that the Maxell cleaned off....
I don't know, but it works now.
I couldn't even use that Maxell DVD Brush cleaner before I manually cleaned the lens, it wouldn't read DVDS!
Either way, I've always had luck manually cleaning lenses in the past, it seems it is still the best way....although a PITA.
muzz is online now
post #2830 of 2843 Old 04-09-2015, 04:31 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Good point. The Bib one with brushes is a CD. Maybe that would have worked? Glad to hear you got it going again. Loaders for the 5k are non-existant these days and I bet for the BH200 it is even worse? I hope ours lasts forever otherwise I will need to install a 5k as the bosses player but she does not watch much media anyway, just whatever comes on cable.
post #2831 of 2843 Old 04-09-2015, 04:36 PM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
I was hoping for HDDVD to win, as I thought it made more sense, but alas Sony threw a ton of $ at BD and it won.
I have way more HDDVDS than BDs(because I stopped buying BDS due to their cost back then, will buy a few now).
This plays BD and HDDVD fine, although it's slow, it works NP.....not buying another BD player until this one stops working, I can deal with a small delay.
tripleM likes this.
muzz is online now
post #2832 of 2843 Old 04-09-2015, 04:46 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Ya, I used to feel the same way, but I got over it. I have a couple racks of HDs and triple that for BD with tons stacked all over everywhere. These are now the days of BD like DVDs back in the day. I just ordered four movies in two double packages brand new and the entire cost to me will be only $2.46 (thanks Freeshipping.com). Granted they are not the best movies out there (The Messengers/Freedomland and Running with Scissors/The Squid and the Whale). I'm collecting Kristen Stewart movies (don't know why) and wanted The Messengers and came upon these BD doubles. I will sell my copy of Running with Scissors and end up making a profit on the whole ordeal.
You are smart waiting. Most movies that have been out for more than a year are cheep and if you don't mind buying used are great values. I typically see many older BD releases or under a buck ("B" titles) and always under $10 for most stuff. Even the new release catalog stuff is usually under $15.
post #2833 of 2843 Old 04-09-2015, 05:04 PM
muzz's Avatar
Quoted: 241 Post(s)
Liked: 127
Gone are the days of paying 30+ for a BD movie.
Been there, done that.....
" Wow, this movie looks and sounds fantastic"
"I just got this...wow"
.......collecting dust, it wasn't that good...
Bah, no more of that, I like my $ too much, and I need it for gear!
tripleM likes this.
muzz is online now
post #2834 of 2843 Old 04-17-2015, 02:23 PM
tripleM's Avatar
You guys are starting to make me tear up thinking about those days back in '07 when we were all scrambling around to get the last Toshiba's & this LG to play our vanquished HDDVD format.
I still use my LG200 about 3-5 times a year...mostly for my watching the Batman trilogies over & over. And soon the Star Wars saga to prep for the the new SW7 this Xmas
Still my main player (only player really).
Haven't updated its firmware since I don't know when but it plays everything that we put in there.
Takes forever to boot upto the play screen but man, it is smooth as butter.
It's really the first machine that I enjoy the audio as much as the video reproductions i.e. TrueDolby & DTS-HD sound is just awesome on it.
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #2835 of 2843 Old 04-17-2015, 04:45 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
I was late to the party. I didn't start collecting HDPs and HD media until the Spring/Summer of '08 AFTER HD had been killed off. Actually I had a D-VHS player (by mistake, $40 on a clearance table) but did not realize what I had until way after I purchased it (for it's firewire output and dubbing old home movies from VHS). I started with collecting, buying, trading, bartering D-VHS tapes and did very well with that then discovered HD-DVD after the fire sale and slowly started collecting BDs once I had purchased all the HD DVD movies I desired at the time. I still purchase a few here and there. They have now taken over my life and living space. I bought my one and only BH200 from Crutchfield as an outlet open box but in actuality it was brand new, just being closed out. I had purchased my first Sammy 5k prior to that and a Sony BD player and a A35 for the bosses TV (which is now in the great room). When I got the BH200 I put it in place of those two units, got rid of a HDMI switch box, gave the Sony to my daughter for a wedding present (didn't get it back after the divorce) and put the A35 in storage. I still get the A35 out every once in a while if I run into a disc that won't play on the LG or the Sammy's. I still have one (Bubble) that won't play on the Sammy. If I remember right it plays just fine on the LG and of course the A35.
post #2836 of 2843 Old 04-26-2015, 08:15 PM
nashou66's Avatar
Quoted: 87 Post(s)
Liked: 102
Did you try to hold the power button down while plugging the Unit in , hold it down a for a few seconds then let go of the power button. Sometimes that trick resets the onboard computer/Motherboard.
Nashou
nashou66 is offline
post #2837 of 2843 Old 04-26-2015, 08:23 PM
microbob's Avatar
Quoted: 31 Post(s)
Liked: 24
Nashou
I did try that. It still would not open the drive. All I would get is blue lights which wouldn't go off so the drive could open.
Robert
microbob is offline
post #2838 of 2843 Old 04-26-2015, 08:25 PM
nashou66's Avatar
Quoted: 87 Post(s)
Liked: 102
Hmmm, I might try to pick up a dead BH200 that does that and try to track down the issue on the Mother board. I like challenges like this one.
Nashou
nashou66 is offline
post #2839 of 2843 Old 04-27-2015, 12:46 AM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Rather than a bad motherboard this might just be a bad loader/drive. I have experienced similar issues with a few other players. Some I have worked on won't boot if the drive is bad or not present (or otherwise does not think it is) others will have symptoms like your "please wait" message due to the same issues. I by no means an expert with the BH200, but am with the Sammy 5K.
If you were not getting the "please wait" message I would blame it on a broken or not on the spindle drawer belt.
post #2840 of 2843 Old 07-01-2015, 08:21 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Hmmm...well rented the boss a couple movies for the long weekend. Popped the 1st BD in and it detected BD went to reading then locks up and resets. It plays CDs, DVDs, HD-DVDs, DVD side of combo HD-DVDs (haven't tried a hybrid HD-DVD yet). Ran a bunch of different lens cleaners through it and still no luck with BDs. We recently watched Big Hero 6 in this player on BD and I also tested Elephants Dream HD-DVD in it since it was not playing in my main Sammy BD-UP5000. I suspect something with playing that HD-DVD in it last time messed it up or the heat has fried the BD laser. Odd since it detects BD just fine an starts to read but instead of getting the yellow > in the upper right corner of the screen it goes blank, locks up and eventually turns itself off and sometimes reboots. I can hear the laser reading the disc just before it locks so I'm in fear that my loader has gone cuput. Any ideas out there before I tear it apart and brute force clean the laser? I have tried the reset procedure in the manual and the hold the power button when plugging in etc. Also cleared all the memory for BDs and HDs and did a factory default setting thing. Nothing is working. Before I tear it apart I am going to force flash the latest firmware onto it and maybe that might beat it into submission. I don't get it if the laser has gone bad, it was fine just a short time ago, has not been on and we have not had any power outages or bumps since then either.
Ideas are appreciated. Guess the boss is going to get one of my many Sammy's to replace this unit?
post #2841 of 2843 Old 07-01-2015, 08:45 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
I forgot about the old factory reset option in the secret firmware check menu (aspect and ling code on remote). Tried that with no luck also. Doing a forced latest firmware now and crossing my fingers that either that or opening it up and cleaning the laser will revive it. Sad, this player has very little use and I bet finding a working loader for it is going to be a major pain.
post #2842 of 2843 Old 07-01-2015, 08:49 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Guess what folks. Forcing a latest firmware update (same exact file I had before) beat this thing into submission and it is working fine now. Either that or it won't play BDs in 80+ degree heat???????? So nice trick it you run into this problem. I'm going to play Elephants Dream in it again to see if playing that disc will kill it. I've seen stranger things happen with these combo players before.
post #2843 of 2843 Old 07-01-2015, 09:43 PM
mr.kludge's Avatar
Quoted: 68 Post(s)
Liked: 107
Ok well I tried ED again and the two of the BDs I rented and tried earlier this evening and nothing would cause it to not play BDs anymore. I am pleased but completely stumped by this. Maybe some of you that think you have bad loaders may be able to try this trick to get things going again. BTW - too lazy to set up a network connection so I just used the same USB stick that I used several firmwares ago back before I had it online. I did a fresh download and compared that file to the one I already had and flashed with the new download just to be sure. At least the laser is pretty clean now and ready for another seven years of hardly being used. I just hope I did not shorten the life of the laser and loader but running cleaning discs in it. I don't like to use my bib brute force cleaner unless absolutely necessary or any brush like cleaner for that matter but regularly use a Maxell wind tunnel disc a few times a year. I know it seems they don't work but it has corrected many issues in the past. The bib was the only thing that would make my Tosh A35 play the UFO Showtime HD import a few years back. I have two copies of the disc and neither would play in anything at one point then Samsung did a firmware update and so did LG but it would still not play in the A35. Stumped one day I decided to run all the cleaning discs and it's worked fine since once I used the bib CD cleaner with the long brushes.. The only disc I had at the time that would not play was that one. I have since purchased a Memorex Blu-Ray lens cleaner that is a DVD and has smaller brushes. 1st time I have used it was tonight as I just purchased it for .90 at FYE a week or so ago. My hope is that one will be more effective than the Maxell wind tunnel disc and less damaging than the bib. Most players choke a bit on the bib as it is designed for CD players.
bluray2009 likes this.
Reply Dual Format Players
