LG BH200: Hidden Hacking Options - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2008, 03:09 PM
Worstepisodeever's Avatar
would I need to have a region B BD to try it out?
Worstepisodeever is offline
Old 05-06-2008, 03:18 PM - Thread Starter
bradavon's Avatar
Hi Worstepisodeever. Thanks for the reply.
To be of any use, yes you'll of course need a Region B locked BD but NO you don't need one to see if it does anything. Follow these instructions:
Check what your SD DVD and BD Region are set to currently, go to:
1. SETUP
2. TV ASPECT
3. SELECT 16:9
4. PRESS 1397139 ON THE REMOTE
5. PRESS ENTER
Then once you know this:
1. Turn the LG BH200 on
2. Open the tray, with no disc in the tray
3. Press PAUSE, 1, 4, 7, 2
4. Change the fourth HEX value to 96. So for USA Models it reads: 55 53 00 96 00 05 00 40
5. Press PAUSE to close EEPROM Menu
6. Turn the LG BH200 off
Whatever the string is you just want to change the fourth value to 96. DON'T change the other values. Make a note of what the string is before you change it and if you wish you can always put it back afterwards (for USA Models it's likely to be: 55 53 00 00 00 05 00 40). 00 is the default value in The USA.
You will then see what the SD DVD and BD Region code is set to. Is it still SD DVD Region 1 and BD Region A?
If it doesn't change anything I'd recommend putting it back to 00, or 8D if you wish to enable PAL support.
bradavon is offline
Old 05-06-2008, 03:30 PM
peterjcat's Avatar
I think a bit of a EUREKA is in order.
Setting Byte 4 to 96 changed my US BH200 to Region B. As reported in the Region Info screen, and verified with Region B The Simpsons Movie (Australian, Fox, region locked).
Thanks Brad & AlfaGT!
peterjcat is offline
Old 05-06-2008, 03:37 PM
Krobar's Avatar
Quoted: 17 Post(s)
What does "06" do?
I should add that using the last 5 bits for complete region control makes sense. You need 2 bits for Bluray and 3 bits for DVD; what I dont understand is the pattern, could really do with a Japanese or Austrailian BH200 EEP readout.
Going all out straight away with "9F" for the BH200 might be risky (Might also be Region Free ).
Krobar is offline
Old 05-06-2008, 03:48 PM - Thread Starter
bradavon's Avatar
WOW! I'm impressed.
* What was the SD DVD Region?
* Could you still play PAL Region 2 SD DVDs?
* I presume you could then not play Region A BDs?
* Is the Network Update option still available?
Actually it probably doesn't matter too much what the SD DVD Region number said (as we have the RMTM CD) but it's still worth knowing.
bradavon is offline
Old 05-06-2008, 03:53 PM
1. SETUP
2. TV ASPECT
3. SELECT 16:9
5. PRESS ENTER
4. Change the fourth HEX value to 96. So for USA/Canadian Models it reads: 55 53 00 96 00 05 00 40
Whatever the string is you just want to change the fourth value to 96. DON'T change the other values. Make a note of what the string is before you change it and if you wish you can always put it back afterwards (it's likely to be: 55 53 00 00 00 05 00 40). 00 is the default value in The USA/Canada.
ill try this when i get home if nobody else beats me to it.
I assume 82 works as well, i think thats what i set mine too....whichever string is listed first on the front page of the faq. just checking.
Old 05-06-2008, 03:55 PM
ah, nevermind. i just read the update that 82 disables the Update option. need to make a note of that and change it to 8D when i get home.
Old 05-06-2008, 03:59 PM - Thread Starter
bradavon's Avatar
Please double check it does disable it in your case. It would be handy to have a second user confirm this is the case. Even though Peterjcat has switched his to Region B it would be useful if someone else confirmed it too (i.e - value 96).
Thanks in advance.
bradavon is offline
Old 05-06-2008, 04:11 PM
Krobar's Avatar
Quoted: 17 Post(s)
If the last 5 bits control Regions......
96 - The last 5 bits are set to 22
Zone B - Region 2?
It still doesnt make sense as to why the USA is 0 though.
Krobar is offline
Old 05-06-2008, 04:30 PM - Thread Starter
bradavon's Avatar
Sorry I don't follow?
My thinking is the USA is DVD Region 1 and it's also BD Region A, the USA also tends to lead and others follow. So 00 would follow with that pattern.
That's just a guess though.
bradavon is offline
Old 05-06-2008, 04:34 PM
peterjcat's Avatar
WOW! I'm impressed.
SD DVD Region was 0 as set by the RMTM CD. It looks like, if you run the RMTM CD, you can't subsequently change the SD region code using the Byte 4. SD region coding can only be changed using the RMTM CD again. This doesn't seem to be a problem except in testing what the EEPROM string means. Anyway, under 96 PAL playback is fine and there is no Network Update option.
Region A playback is not possible with 96 (tested with The Lives of Others, Sony, US, Region A Locked). However, you don't need to reboot the BH200 to change the BD region code. I was able to swap between Region A and B and play Region A- and B-locked movies using PAUSE-1-4-7-2 and changing Byte 4 between 8D and 96.
I guess we need some more non-US BH200 users to post their Byte 4s and see if we can work out the patterns. Ones I have tried are:
00 = 0000 0000 = R1/RA/NTSC/Network Update
80 = 1000 0000 = R1/RA/NTSC+PAL/Network Update
82 = 1000 0010 = R2/RA/NTSC+PAL/No Network Update
8D = 1000 1101 = R4/RA/NTSC+PAL/Network Update
96 = 1001 0110 = R2?/RB/NTSC+PAL/No Network Update
I don't know if the binary values are in any way significant, but it might be the case that Bit 1 enables PAL and maybe Bit 4 is the BD region code. The SD region code could be somewhere in Bits 5-8 but the pattern isn't obvious. Anyway it might not be binary at all, there could be an internal table that translates between the EEPROM numbers and a matrix of values.
I seem to remember that the BD region coding is designed such that there can be no such thing as a multi-region BD player, it has to decide each time whether it's going to be A, B or C. All of the (hardware!) BD multi-region solutions have involved switching between A or B. So we may be out of luck finding a single EEPROM value that will allow A/B/C playback, but the little LG has already surprised us.
As far as I know this is by far the simplest way to play an off-region BD in any BD player. The others involve hardware or flashing the whole firmware. Ours doesn't even need a reboot, though you need to be handy with the remote.
I'd love to sit here and test all the possible Byte 4 values, but given the risk of bricking I might leave that to someone who lives closer to where they bought the unit.
Old 05-06-2008, 05:03 PM - Thread Starter
bradavon's Avatar
AlftaGT (Swiss Player) has PMed me saying:
Originally Posted by AlfaGT View Post
"I changed my 4th digit from 96 to 8D (Australia: NTSC, PAL & Network-Support) - Result:
* Finally had in the others-menu the long awaited point to make fw-updates over ethernet
* Thats the annoying point: My BR-Region changed from Region B to Region A.
Yes, I already found out that Australia is in B too. But I really set it to 8D and was no longer able to look my Fox and Disney Region B Blu's . There appeared a pop-up when playing the disc: "This FOX Blu-ray disc is ......blablabla (I don't remember)". I didn't check the region info window, but I tried Region B Blu-rays and Code 1 and 2 DVD's
Perhaps the 8D is something other on the BH200 than on the BH100??"
It's occurred to me all the users who've so far tested 8D are using an American BH200 so would be on Region A anyway. The user with a BH100 definitely has a Region B BD Player though (the guy who posted his was 8D originally):
"My player is an Australian player and is SD-DVD region coded to Region 4"
Source: http://www.avsforum.com/avs-vb/showp...&postcount=720
Good point . That's how that Dutch company does it, you do it on the remote.
Agreed. I would be wary about switching back and forth between values in the EEPROm "too much" though. You wouldn't want to brick the Player.
I don't know if the binary values are in any way significant.
Where are you getting the binary number from btw?
Great post btw, good work there.
bradavon is offline
Old 05-06-2008, 05:11 PM
peterjcat's Avatar
It's just the hex code expressed in binary -- that's what Krobar was talking about with the last 5 bits.
Old 05-06-2008, 05:16 PM - Thread Starter
bradavon's Avatar
Following from the likelihood 8D on the BH200 means BD Region A (but on the BH100 it means Region B), these two codes would seem the most useful:
8D = R4/RA/NTSC+PAL/Network Update
96 = R2?/RB/NTSC+PAL/No Network Update
At least we have a some way to switch between Regions, even if it is a bit messy.
Understood, thanks.
Agreed. The Non-USA/Canadian members I know of are:
AlfaGT - Region B bought in Switzerland - Fourth value 96
Krobar - Region B bought in Belgium - On order
ISO-HD - Region B bought in France - Fourth value unknown
Julio Cohen - Mexican but he has a USA BH200
StardustOne - Swiss but he has a USA BH200
Bradavon - I'll hopefully have one soon
I PMed ISO-HD earlier tonight, if he replies I'll ask him to let me know his EEPROM string.
bradavon is offline
Old 05-06-2008, 06:01 PM - Thread Starter
bradavon's Avatar
Peterjcat: When you set your USA BH200 to 8D did the Region Info window say it was set to SD DVD Region 4?
Irrespective of what you'd set with the RMTM CD, clearly this (as you say) overrides the EEPROM menus SD DVD Region setting.
The reason I am asking possibly the obvious is South America is:
* BD Region A
* SD DVD Region 4
I bet that's what 8D is meant for: South America
bradavon is offline
Old 05-06-2008, 08:04 PM
dring's Avatar
My Canadian BH200 originally had EEPROM value 43 41 00 01 00 05 00 40.
The initial 43 41 is ASCII hex for "CA", the country code for Canada.
Interestingly, the fourth byte was originally 01, not 00 as in the U.S. models. It had the same characteristics as the U.S. models, i.e., DVD Region 1, BD Region A, NTSC-only, Network Update available.
I have since changed that byte to 8D to enable PAL, thanks to the splendid info unearthed in this forum.
dring is offline
Old 05-06-2008, 08:25 PM - Thread Starter
bradavon's Avatar
Thanks Dring
I don't suppose you could try replacing 8D with 96 and then report back what the:
* SD DVD Region
* BD Region
Are set to in the Region Info menu? You can see how to access this here:
http://www.avsforum.com/avs-vb/showp...&postcount=155
By all means then put it back to 8D afterwords. It would be good to have further confirmation that 96 changes a BD Region A model to BD Region B, especially as your model is Canadian not USA.
p.s - Thanks for the info the default Canadian string differs. I've updated the Mini-FAQ.
bradavon is offline
Old 05-06-2008, 08:29 PM
peterjcat's Avatar
* BD Region A
* SD DVD Region 4
Since I applied the RMTM CD, nothing changes the SD DVD setting in Region Info window. It's always whatever I set using the RMTM CD. Before I applied the RMTM CD, I didn't look at the display but using 8D the BH200 only played R4 SD DVDs.
The 8D came from an Australian BH100... it may be that 8D isn't "meant" for any BH200 -- certainly not the Australian once since that would be Region B, maybe a South American one but I don't know if LG is planning to release a South American version. It sure would be handy if they did!
It may just be coincidence that the BH100's 8D code has the observed effects on a BH200. It all does seem to point to the idea that the binary digits are significant.
Old 05-06-2008, 08:41 PM - Thread Starter
bradavon's Avatar
Thanks again Peter.
It would lend evidence to my theory the RMTM CD overrides whatever SD DVD Region is set in the EEPROM menu. I bet if you put it back to R1, changing the EEPROM value still wouldn't change it, the RMTM setting has now taken over.
Hopefully ISO-HD (France) will get back to me so we can see if his is set to 96 too. I'm sure Krobar (Belgium) will tell us his when it arrives.
I don't know if they are either but it's certainly possible the code is for South America even if LG haven't actually released one there. The fact the Aussie BH100 is 8D and on the BH200 8D also sets it to SD DVD Region 4 is too big of a coincidence IMO, even if like you say the numbers don't quite add up (Australia is BD Region B). Not that it ultimately matters where the codes are meant for.
The sad truth is (except for the BH100) both LG and Samsung have all but given up on Combos outside of North America. Samsung of course even more so.
I heard in the UK, LGE will only allow a retailer to buy a minimum of 30 units. Who is going to buy 30? That's some risk when they've no idea how well they'll sell and virtually no one in the UK know they exist. If it wasn't for a few loyal fans (like me ) the thread over at AVForums.com (UK equivalent) would be dead.
I think the EEPROM menu is the same but the codes each use are different, but some codes share similar functionality. We know for instance 02 does naff all on a BH200.
bradavon is offline
Old 05-07-2008, 12:17 AM
dring's Avatar
* SD DVD Region
* BD Region
bradavon,
Note that I had previously used the RMTM CD to set the DVD region to 0. Therefore, my System Information screen was showing:
DVD Region: 0
BD Region: A
When I changed EEPROM byte 4 from 8D to 96, it then showed:
DVD Region: 0
BD Region: B
PAL was still enabled, and the Network Update menu item disappeared.
As you have noted, changing EEPROM byte 4 doesn't override the DVD Region setting made by the RMTM CD. However, I found that if you perform a Factory Reset by pressing PAUSE on the System Information screen, the DVD Region code does get changed to what you would expect, i.e., 8D -> R1, 96 -> R2. Note that this change does NOT occur when you perform a Factory Reset from the normal user menu (SETUP->OTHERS->Initialize->Factory Reset).
dring is offline
Old 05-07-2008, 12:53 AM
dring's Avatar
Over in the BH100 thread, Krobar mentioned a few other "remote codes for LG users to try". Unfortunately, the one for turning HDCP off/on didn't do anything for me. But his third sequence did produce an interesting result. Entering:
PAUSE, 2, 4, 8, 6, 5
brought up a screen with three choices:
1. System Log, 2. ATAPI Log, 3. HDMI EDID
Entering 3 displayed the EDID info received from the display via HDMI, which might be useful, e.g., for determining if your display claims to support 50 Hz or 24 Hz resolutions.
But the especially interesting one, with respect to the topic of this thread, was choice number 1, System Log. That displays a typical log of software activity. You can page through it using the up and down direction keys on the remote. Press RETURN to get back to the choice among System, ATAPI, and EDID. Press RETURN again to get back to normal operation.
On about page 15 of the System Log it lists "Player Option Information". For my Canadian BH200 with its factory default setting, it gives the following info:
MODEL: SMB_PLAYER_CANADA
Country: CA
Option Code: 43 41 00 01 00 05 00 40
Initial Language: English
TVSystem: NTSC
BDRE: Enabled
BD: Enabled
BD9: Enabled
HDDVD: Enabled
3xDVD: Enabled
Screen Saver: 5
Show Mode: OFF
Admin Mode: OFF
Auto Power Off: ON
When I change EEPROM byte 4 to 8D, three of the above lines change value:
MODEL: Non name model
Option Code: 43 41 00 FFFFFF8D 00 05 00 40
TVSystem: PAL
(That's probably just a print formatting or conversion bug in the 4th byte of the Option Code, treating it as a signed byte, converted to a 32-bit hex value.)
I would guess that the above list of parameters are all encoded in the EEPROM string. That one labeled "BDRE" looks interesting; might it stand for something like "Blu-ray Disc Region Enforcement"?
dring is offline
Old 05-07-2008, 01:32 AM
Krobar's Avatar
Quoted: 17 Post(s)
Looking at this a couple of things are known:
Bit 7 - If on enables PAL
Bit 6 - ?
Bit 5 - Part of BR Zone Control??
Bit 4 - Part Of BR zone Control
Bits 2 & 3 - Control SD Region
Bit 1 - If on disables Network
Bit 0 - ?
94 - Should enable network update on Euro Player
We need to find out if Bit 5 really is involved in Zone Control. Anyone willing to risk trying "A0"?
Krobar is offline
Old 05-07-2008, 01:43 AM
AlfaGT's Avatar
I will try changing 96 on my Euro Player (Switzerland) to 94 to find out if it really enables me the network update - Will try this evening when back from work.
By the way: Thanks to All for the endless support and all the testing.
I think some day, we find out some interesting things that let us enable some cool features
Cheers
AlfaGT
AlfaGT is offline
Old 05-07-2008, 02:44 AM
peterjcat's Avatar
Bit 6 - ?
Bit 0 - ?
These are supportable assumptions but I don't think we can call all of them "known" yet. For example, there are six DVD regions (plus Region 0) so you'd probably need three bits to cover all the possibilities. The Network setting might follow from the DVD region (eg if you're in Europe you don't get an update) but I guess we'll see when AlfaGT gets home
I would guess that BDRE stands for recordable Blu-ray discs, ie BD-REs. But maybe that's too prosaic.
Old 05-07-2008, 03:01 AM
Krobar's Avatar
Quoted: 17 Post(s)
As I mentioned earlier you need 3 bits to cover all dvd regions and 2 bits to cover all BD zones. Maybe LG thought only Regions 1-4 needed to be available.
I dont understand why they would tie in network connectivity with the DVD region but you are right that we are not 100% sure on what Bit 1 does so AlfaGT you may not want to try 94 just yet.
Krobar is offline
Old 05-07-2008, 04:34 AM
AlfaGT's Avatar
...we are not 100% sure on what Bit 1 does so AlfaGT you may not want to try 94 just yet.
Guys, you are really funny
Decisions, decisions, decisions.......shall I try or shall I not try
I've another 5 hrs to make my decision. I let you know
Cheers
AlfaGT
AlfaGT is offline
Old 05-07-2008, 06:22 AM
peterjcat's Avatar
I just meant it as an example: not all the features are necessarily represented by discrete bits in the EEPROM. Since Network Update wasn't included until the most recent firmware, and maybe wasn't contemplated on first release, it might not have its own bit in the EEPROM. Then again, it might. We'll see what AlfaGT decides
Old 05-07-2008, 09:00 AM - Thread Starter
bradavon's Avatar
Originally Posted by dring View Post
When I changed EEPROM byte 4 from 8D to 96, it then showed: DVD Region: 0, BD Region: B
Excellent. It's good to have a second confirmation. I wonder why Euro Players have the Network Update option disabled, weird.
So performing a Factory Reset puts it back. It's good to hear we have a way of reversing the change the RMTM CD makes.
Is there a way to tell if HDCP is enabled/disabled?
ATAPI log will be about the connection used from the physical drive to the Motherboard:
http://en.wikipedia.org/wiki/ATAPI
That's interesting news about the HDMI EDID log.
I bet it just means Blu-ray Disc recordable:
http://en.wikipedia.org/wiki/BD-RE
Especially as after BDRE is BD. On the Samsung Combo it doesn't work. I wonder what Admin Mode is for?
Great work there thanks Dring. I'll add the hack to look at System Info to the Mini-FAQ. I've not added about making changing the BH200's BD Region as I don't think testing is complete on that one yet.
bradavon is offline
Old 05-07-2008, 09:07 AM - Thread Starter
bradavon's Avatar
If it were me I'd probably try 94 but it's not an official code like 96 is so I'd have to give it some thought. Take Krobar and Peter's advice on this one though, they know more about how the binary values work than I do.
Are you planning to try this and 06 you mentioned previously? It maybe safer is someone like you tries them as you have a better understanding of how the binary codes work than AlfaGT and I.
bradavon is offline
Old 05-07-2008, 09:44 AM
robertpierre's Avatar
I changed my EEPROM code from 82 to 80. As indicated elsewhere, it restored the "network update" entry in the home menu, without affecting the PAL playback or BD region code. The SD DVD codes are controlled by the hack, so this change did not affect Region 0 display in the summary screen.... 80 seems to be as valid as 82 or 8D entries
BH 200 (55 53 00 80 00 05 00 40) PAL/NTSC w.Network Update and region code hack, F/W December 08, driver 702 connected by SPDIF to Yamaha HTR 6060 and by HDMI to Toshiba Monitor 26HL84
robertpierre is offline
