LG BH200: Hidden Hacking Options - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2008, 09:41 PM
robertpierre's Avatar
The easiest comparison is to jumper switches on computer MOBO - they have ON/OFF switches, so jumper 1 in off, jumper 2 in on, jumper 3 in on and jumper 4 in off would equal binary 0110, which happens to be HEX 6. So we are looking for the right combination of 1 and 0 and so far all variants of bits from 0 to 4 (each byte, that is HEX word such as 8D has 8 bits from 0-7, with 4 binary numbers representing each HEX half-word) in byte 4 of the EEPROM don't give us BD region free
BH 200 (55 53 00 80 00 05 00 40) PAL/NTSC w.Network Update and region code hack, F/W December 08, driver 702 connected by SPDIF to Yamaha HTR 6060 and by HDMI to Toshiba Monitor 26HL84
robertpierre is offline
Old 05-07-2008, 09:59 PM
peterjcat's Avatar
My further reckless testing shows that 90, C0, D0, E0 and F0 all remain Region A, though all preserve PAL playback and network update.
This is interesting because 90 (RA) shares the same first four bits as 96 (RB) which suggests to me that it's not as simple as the BD region info being somewhere in the first four bits only.
So what does 96 = 10010110 = RB have in common with A0 = 10100000 = RB but not with 90 = 10010000 = RA? I've got no idea.
peterjcat is offline
Old 05-07-2008, 10:39 PM
peterjcat's Avatar
What do they have in common? I'm glad I asked.
Having a look at the System Log after each of these changes, one thing emerges. So far, only official codes for Byte 4 give you Region B, all others default to Region A. As we know, 96 is the official code for Switzerland, and this is confirmed in the System Log. I don't know if we knew this before, but according to the System Log A0 is the official code for Spain. Both of these give us Region B. Everything else gives an "Unknown", which gives us Region A.
Now, information about the name of the code version obviously isn't contained within the EEPROM settings, yet it turns up in the System Log. So there must be an internal list of official codes in the BH200's firmware, along with the name of that code and maybe also the BD Region Code. Maybe for BD region coding the BH200 doesn't care what the actual bits are, it just tries to look up the code and apply the right region, and if it doesn't find it it defaults to Region A. So it's not the individual bits, it's the whole number.
I'm guessing that if we knew what the official code for Russia was, we'd get Region C. If we knew what the official code for Utopia was, we might get a region-free player
So far all the official BH200 codes we've seen are (in decimal) multiples of 10: 00 = 00 = US, 96 = 150 = Switzerland, A0 = 160 = Spain. But that's a pretty small sample, and AA = 170 = Unknown, and I haven't tried any more.
Old 05-07-2008, 11:14 PM
peterjcat's Avatar
More multiples of 10:
0A = 10 = Yugoslavia (RB)
14 = 20 = North Africa (RB)
1E = 30 = Austria (RB)
32 = 50 = Brazil (RA)
3C = 60 = United Arab Emirates (RB)
46 = 70 = Hong Kong (RA)
82 = 130 = Mexico (RA)
8C = 140 = Czech Republic (RB)
No sign of any Region C, and no "Test Mode" or anything promising like that.
Old 05-08-2008, 12:08 AM
peterjcat's Avatar
And not just multiples of 10 it turns out...
91=France, 92=Benelux, 93=Turkey, 94=North Africa again, 95=Egypt, 9A=UK, 9B=Italy, 9C=Greece, 9D=Germany, 9E=Austria again, 9F=Portugal.
Discovery! As we suspected, the first bit does seem to control PAL/NTSC, and the last seven make up the official code number. So 11=France NTSC, 91=France PAL, 14=North Africa NTSC, 94=North Africa PAL, 01=Canada NTSC as already reported, 81=Canada PAL, 02=Mexico NTSC, 82=Mexico PAL, and so on.
Further observations:
In the System Log, Byte 4 is called VIDEOTYP_HEX, suggesting what we already knew ie Byte 4 has a lot to do with the video type.
The variables in the "Player Option Information" part of the System Log are:
Model: which comes from the last 7 bits of Byte 4 (eg "SPAIN").
Country: which comes from Bytes 1 and 2 (eg "US", you can make it spell anything).
Option Code: which is just the whole EEPROM string, eg 55 54 00 B0 00 05 00 40.
Initial Language: which is English.
TV System: which comes from the first bit of Byte 4 (NTSC or PAL).
BDRE/BD/BD9/HDDVD/3xDVD: all enabled
Screen Saver: 5
Show Mode: OFF
Admin Mode: OFF
Auto Power Off: ON
Now I wonder whether the 5 in Byte 6 is the same as the 5 in Screen Saver; whether the positive value for Byte 8 correlates with the positive in "Auto Power Off: ON" -- and accordingly whether the Admin Mode, which sounds very interesting, has something to do with Byte 7.
But I'm not currently game to try changing Byte 7.
Old 05-08-2008, 12:24 AM
Krobar's Avatar
Quoted: 17 Post(s)
PeterJCat,
Thank you for your valuable testing.
Krobar is offline
Old 05-08-2008, 12:43 AM
AlfaGT's Avatar
Originally Posted by bradavon View Post
Thanks AlfaGT. I presume when set to 00 you couldn't play PAL DVDs?
Right, sorry I didn't mention because we are focussing at BD Region
So, it looks like 00 does disable PAL-playback on a Euro player too.
Following the last tests with A0 and B0, it looks like A0 is the better choice for a Euro-player, because it does not change the BD Region from B to A and does finally enable the web-update ? I will give it a try and when it's like this, I will finally change my 96 to A0. Thanks for testing this risky not official codes
Cheers
AlfaGT
P.S. I am also looking forward and think one day we will find a Code for setting the LG region-free for Blu's. This day I will make a BIG party, you are all welcome at my home
AlfaGT is offline
Old 05-08-2008, 02:05 AM
dring's Avatar
Originally Posted by peterjcat View Post
I would guess that BDRE stands for recordable Blu-ray discs, ie BD-REs. But maybe that's too prosaic.
You are, no doubt, correct about that (as further suggested by bradavon). Spoil sports!
Is there a way to tell if HDCP is enabled/disabled?
I do happen to have a way. I have all my sources outputting to a DVDO VP50Pro scaler, which then feeds a JVC projector via DVI with HDCP. In the scaler, for each HDMI source I can specify whether or not that source requires HDCP. If I specify that a source does not require HDCP, but it really does, then I get a blank screen (because the source refuses to send on an "unsecured" HDMI link). Thus I can tell which sources are enforcing HDCP and which are not.
When I tried Krobar's sequence to turn HDCP on/off (from the BH100 thread):
PAUSE, 1, 2, 3, 6, 9
I did not get the expected screen message that he mentioned, and the HDCP behaviour of the BH200 did not change. However, it did cause the display on the front of the BH200 to read "NO USB".
The same dumb reason North American Players have PAL disabled I'd image: Stupidity!
Actually, it might not be entirely stupid. When PAL is enabled, the machine initially outputs 50 Hz video, until you fire up an NTSC DVD or an HD disk. Many TVs in North America do not support 50Hz video, so anyone owning such a TV would fail to see the initial splash screens or the "Home" menu that appears if no disc is inserted (to allow player set-up, etc.). It's therefore safer and friendlier to start up in 60 Hz mode when used in NTSC-land.
dring is offline
Old 05-08-2008, 02:56 AM
dring's Avatar
Yes, I made the same discovery tonight. I'm sorry you beat me to it!
Another, smaller discovery: If you perform a Factory Reset by hitting PAUSE while viewing the System Information screen, the first two bytes of the EEPROM (the country letters) and the high-order (PAL) bit of byte 4 get changed to the default values for the model identified in the low-order bits of byte 4.
For example, I had my EEPROM set to 43 41 00 80..., which is:
Model: SMB_PLAYER_USA
Country: CA
TVSystem: PAL
(I was testing robertpierre's reported initial EEPROM string, which combined the "CA" letters with the USA model code, but I also happened to have PAL turned on.)
When I did a Factory Reset, it changed my EEPROM string to 55 53 00 00..., which is:
Country: US
TVSystem: NTSC
In other words, it "corrected" the country letters to "US" and disabled PAL, based on the model encoded in byte 4.
I discovered earlier that the factory reset also restores the DVD region, undoing the effect of the RMTM CD, presumably also based on the model encoded in byte 4. (I have only tested that the 01 Canada model code will reset the DVD Region to 1. Perhaps others can test their own countries.)
The DVD Region setting is evidently stored elsewhere, perhaps in an EEPROM built into the optical drive unit, which the program on the RMTM CD is manipulating somehow. Does anyone here know how that program works, or have the source code? Perhaps the BD region is handled similarly (or completely differently, in order to give us new challenges)?
The fact that the DVD and BD region settings are not listed in the "Player Option Information" section of the System Log is further evidence that those quantities are not directly encoded in the EEPROM string, and that achieving complete "BD Region freedom" will require poking elsewhere.
dring is offline
Old 05-08-2008, 09:00 AM
I agree with previous post that ADMIN MODE sounds promising and the answer may truly lay in Julio's region hack program - after all the result of applying it is a Test/admin mode screen - maybe that is just a subset of the full Admin mode function?????
Old 05-08-2008, 10:05 AM
oilblue's Avatar
Wow. Outstanding work peterjcat and dring! Thanks!
oilblue is offline
Old 05-08-2008, 10:39 AM - Thread Starter
bradavon's Avatar
Thanks for explaining Robert. I know all about Motherboard jumpers.
You can see the Region C countries here: http://en.wikipedia.org/wiki/Blu-ray#Region_codes
It seems Region A is default and then it changes to B or C when needed. That would make sense with The Far East being Region A.
Thanks for confirming it Alfa.
Thanks Dring for the update how you know the HDCP hack doesn't work. That's weird about No USB.
I asked the LG Engineer what the RMTM CD is and how it works, their response can be read at the bottom of my discussion with them:
http://www.avsforum.com/avs-vb/showp...&postcount=152
If you ask me I don't think the answer lies in the RMTM CD but I could be wrong.
I second that. Excellent work guys.
It seems like we're getting closer and are working out how the EEPROM menu works but alas so far, the best two codes still seem to be:
8D = 1000 1101 = R4/RA/NTSC+PAL/Network Update
96 = 1001 0110 = R2?/RB/NTSC+PAL/No Network Update
Unless anyone thinks another two codes are the best "overall" ones?
Have we found a code that gives us? -
RB/NTSC+PAL/Network Update
bradavon is offline
Old 05-08-2008, 10:45 AM
Yes! A0 - it seems to be the official code for Spain.
Old 05-08-2008, 10:51 AM - Thread Starter
bradavon's Avatar
Thanks Robert. I didn't realise A0 enabled the Network Update too. Any idea what the Official Code for the UK (or GB) is?
It seems PAL means PAL + NTSC, but NTSC means NTSC Only.
bradavon is offline
Old 05-08-2008, 11:08 AM
Krobar's Avatar
Quoted: 17 Post(s)
Just got my BH200 from Belguim and updated the firmware and loader
EEP Data is:
55 53 00 92 00 05 00 40
Krobar is offline
Old 05-08-2008, 11:09 AM
Krobar's Avatar
Quoted: 17 Post(s)
He said its 9A
Krobar is offline
Old 05-08-2008, 11:12 AM
I would imagine that the string would start with 55 4B (UK) but to find out default country code for byte 4, more testing and checking entries in the player log is necessary.......
Old 05-08-2008, 11:14 AM - Thread Starter
bradavon's Avatar
Thanks Krobar.
WTF your Belgian BH200 has a US code (55 53) with it. I wonder if it was originally from America but then altered to Euro use.
Do 92 and 9A enable the Network Update?
bradavon is offline
Old 05-08-2008, 11:15 AM
By the way, yes, PAL/ NTSC switch is the two-way single bit binary switch: binary 0 - default NTSC only, binary 1 - NTSC and PAL
Old 05-08-2008, 11:51 AM
nikonjava's Avatar
http://www.videohelp.com/dvdhacks/lg-ht902tb/8451
I tried the 0000 trick, it didn't work on BH200. The RMTM CD thing is probably similar to what Julio came up with.
http://www.videohelp.com/dvdhacks/lg-dv298h/8305
http://www.videohelp.com/dvdhacks/lg-rc199h/7144
From this link :
"Click the home button on the remote, goto the Setup page, highlight the 16X9 aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of option 5 with the value of: ff
Changing this value will set unit to region code 0 which should allow any region to be played on the player. Hit the return button to save and exit. Reboot the device - all is well now."
Another drive link :
http://www.videohelp.com/dvdhacks/lg-lda-830/8404
http://www.digitalfaq.com/downloads/dvdhackarchive/
I was looking to see if any of these have any other EEPROM values for PAL hack since 80/82/8D create resolution problems for me. I tried the 2 new values from one of these posts - D7 and D0 - but ended up having same resulution problems.
D7 and D0 were mentioned also for VCDs in one of the posts.
Just fyi.
No electrons were harmed during the creation, transmission or reading of this posting. However, many were excited and some may have enjoyed the experience.
nikonjava is offline
Old 05-08-2008, 11:59 AM - Thread Starter
bradavon's Avatar
Originally Posted by nikonjava View Post
From this link :
On the BH200 this is the Hack to display the Region Code Info.
I presume you cannot do this on the BH200? In relation to the above hack.
bradavon is offline
Old 05-08-2008, 12:36 PM
has anybody tried FF as in the post above? Is that info screen even editable?
Old 05-08-2008, 12:54 PM
Krobar's Avatar
Quoted: 17 Post(s)
Thanks Krobar.
It has a 240V PSU so was not destined for USA!
Krobar is offline
Old 05-08-2008, 01:01 PM
AlfaGT's Avatar
Unfortunately not! I tested some other codes on my EU player and I think it's time to present the whole result in a updated overview:
cd./DVD/BR/NTSC/PAL/ NW-update / country
00 / 1 / A / yes / no / yes / US
80 / 1 / A / yes / yes / yes / ?
82 / ? / B / yes / yes / no / ?
92 / 2 / B / yes / yes / no / Belgium
96 / 2 / B / yes / yes / no / Switzerland
A0 / 2 / B / yes / yes / no / ?
9A / 2 / B / yes / yes / no / UK
8D / ? / A / yes / yes / yes / ?
So, my conclusion:
- For US players: 80 or 8D (PAL enabled) would be best (from a technical view)
- For EU players: There is no code available enabling network-update
Is there anyone out there who has other results?? Is there an European-code which enables network-update, do I have missed something??
Can I make a proposal? I think it's perhaps the best, we create a new thread with an overview in the first post (called: "the endless search for region-free BD setting - clearly arranged by Bradavon THE LGMaster" . Sorry, but sometimes I lose overview. Collecting all important information and results in one single post would be very handy.
Cheers
AlfaGT
AlfaGT is offline
Old 05-08-2008, 01:09 PM
AfaGT, are you sure A0 disables network update? BTW, it seems to be Spain- specific code.
Old 05-08-2008, 01:17 PM
AlfaGT's Avatar
yep, unfortunately I am pretty sure. But I think it's best to double-check it with another euro-player - any volunteer .
Sorry for the bad news. But is network-updating so important? I personally can live without it and make my updates with an USB-stick. For me, the more important question is: How to make the LG region-free on Blu's? But you're right network-updating would also be great and would make life more comfortable
AlfaGT is offline
Old 05-08-2008, 01:18 PM - Thread Starter
bradavon's Avatar
I was wondering if a 240v PSU was added after. It seems odd a Euro model would have a US code, not that it ultimately matters.
It seems not. If I were you I'd leave it on 96 (until we come up with something better). You shouldn't need to check the Network Update "that" often.
I think it's too early to create an official thread, further testing needs performing. I was planning to update the Mini-FAQ when we have codes considered final.
I don't think we need to keep a track of every code variant just the best ones that give:
1. Region A + PAL + Network Update
2. Region B + PAL + Network Update/No Network Update
3. Region Free + PAL + Network Update/No Network Update
So, my conclusion:
To clarify:
If you want Region A: 80 - PAL and Network Update
If you want Region B: 92 (Belgium) or 96 (Switzerland) - PAL but no Network Update
92 and 96 seem interchangeable. I am specifically picking these values as we know LG themselves have used them, so at least they have the edge over the other Region B values.
bradavon is offline
Old 05-08-2008, 01:20 PM
I cannot help thinking, that if we could figure out how to set ADMIN MODE to ON, we may be closer to the perplexing BD solution - I personally have lost faith that it is coded in the EEPROM string
Old 05-08-2008, 01:21 PM - Thread Starter
bradavon's Avatar
I presume the option disappeared from the menu?
No it's not important in the grander scale of things but if we could find a Region B code that Enables Network Update that would at be a step forward.
I think you're right. I do think there is a BD Region Free code in the EEPROM string but I am unconvinced we'll be able to find it. It's not as if any Players have the code by default.
Agreed it would be very handy to work out how to enable Admin Mode.
bradavon is offline
Old 05-08-2008, 01:36 PM
AlfaGT's Avatar
Right. And please note (@all), to always shut off your player when changed the digits and switch on/reboot before testing. The new settings are not "ready" till you have rebooted. The option is the last one in the "others" section. So it's an easy one to look at.
And you're right, perhaps its to early to make an own thread. I will pay more attention to not miss / overview the important informations
AlfaGT
AlfaGT is offline
