Playback of AVCHD files on Samsung 5000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-27-2008, 06:40 PM - Thread Starter
dockhan's Avatar
I have a Nov.07 build of a Samsung BD5000 that I'm pretty satisfied with and am now considering purchasing a flash based HD AVCHD camcorder such as the new Canon Vixia HF10 and am wondering if anyone has had any success playing back a DVD with the AVCHD files burnt on them in 1080p or 1080i?
Canon and Sony sell portable standalone burners that connect to their camcorders and which can burn these AVCHD files in full HD on a regular DVD which can then be played back in full HD on a PS3 and supposedly on any Blu Ray player.
Any advice will be deeply appreciated.
dockhan is offline
post #2 of 9 Old 04-28-2008, 08:14 AM
allargon's Avatar
Quoted: 52 Post(s)
Liked: 44
You can create an AVCHD test disc using the one found in the calibration forum. AFAIK, the only Blu-Ray players that support AVCHD are the Panasonics, the Sony standalones and the PS3. The Samsung standalones don't.
http://www.avsforum.com/avs-vb/showthread.php?t=948496
allargon is offline
post #3 of 9 Old 04-28-2008, 03:18 PM
longshot94's Avatar
No it doesn't only units so far reported working is Sony Units, PS3, Panasonic, Pioneer, and the LG BH200
longshot94 is offline
post #4 of 9 Old 04-29-2008, 11:58 AM - Thread Starter
dockhan's Avatar
Do you think that this can be changed in the future by a firmware update or does the player have the required hardware?
dockhan is offline
post #5 of 9 Old 04-29-2008, 12:57 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
I think it is just a firmware issue. AVCHD does not require anything new hardware wise to play them back. The AVCHD file format even mimic BD movie file format so the firmware fix should be extremely easy to implement.
Foxbat121 is online now
post #6 of 9 Old 08-21-2008, 12:46 PM
acug's Avatar
Title says it. I thought the licensing agreement stipulated that both AVC and VC-1 decoding was mandatory in all players carrying the Blu-ray logo.
acug is offline
post #7 of 9 Old 08-21-2008, 01:21 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
AVC is a video compression method. AVCHD is a file format that is used by HD Camcorders. BTW, the latest Samsung BD-P2550 manual states support of AVCHD as well as BD-R/RE discs. Hopefully, we will see them trickle download 5000 firmware.
post #8 of 9 Old 02-08-2009, 04:24 PM
Kurt Doerffler's Avatar
Has anyone burned a disc using the avchd format from a HD camcorder to see if it will play in the BD-UP5000?
HD nut
Kurt Doerffler is offline
post #9 of 9 Old 02-08-2009, 05:15 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
I did and it doesn't work on 5000.
Reply Dual Format Players
