LG BH-200 SD-DVD region hack - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 146 Old 03-23-2008, 06:40 AM
bradavon's Avatar
This MR Hack has only ever been tested with USA Players. I don't think anyone's tested it on European Players.
It's not European software.
bradavon is offline
post #32 of 146 Old 03-23-2008, 07:42 AM - Thread Starter
Julio Cohen's Avatar
Hi everyone,
Since it just activates the region changing menu, worth a try with european players.
But if the European players actually plays NTSC DVDs, loading the US players with the european firmware should work, if they are not equal.
BR
Julio Cohen
Julio Cohen is offline
post #33 of 146 Old 03-23-2008, 08:02 AM
bradavon's Avatar
Thanks. I thought so.
So far no one has had the guts to try this.
It seems the firmware downloaded from the USA and Irish sites are identical, although they may have an identical file size but in fact be different. European models will support PAL that much I do know. How it's achieved I've no idea.
I'm not sure I'd risk bricking my USA Player by trying a European firmware on it.
EDIT: Going to:
http://ie.lgservice.com/
Which is the Irish website, says when you go to download firmware:
This firmware file is apply for USA and Canada only.
A. This could indeed mean they're the same and PAL is done elsewhere in the Player.
B. LG have just copy/pasted info across websites. Considering they put the March firmware inside the January ZIP file (which is the only reason we all have it) I could well believe this.
Regardless that's shoddy working on an Irish LG website.
bradavon is offline
post #34 of 146 Old 03-23-2008, 09:59 AM
zabus's Avatar
could it be possible when loaded the european software version in my us player it plays pal and ntsc or is that not to get by software but hardware?
zabus is offline
post #35 of 146 Old 03-23-2008, 10:11 AM
bradavon's Avatar
Cheeky you've already asked that
Personally I think it's done elsewhere in the player, so if not hardware another part of the Player but not Firmware. To give you an idea what I mean, Julio Cohen is changing data in one of the EEPROM chips to make the LG BH200 SD DVD Multiregion but he is not touching the Players Core Firmware, which is done when we install Firmware Upgrades.
If it's not done in Firmware PAL/NTSC could be stored elsewhere and it looks likely it's not being done in Firmware (i.e - the files on the USA & Irish sites appear identical). In short I doubt installing the European Firmware will give you PAL compatibility. I'm no LG Engineer though so could obviously be wrong.
So far no one has had the guts to try the European Firmware (technically not Software) in a USA Player to be able to say either way. Do you fee like being a guinea pig?
bradavon is offline
post #36 of 146 Old 03-23-2008, 10:15 AM
benc5's Avatar
Originally Posted by bradavon View Post
That's a pity. Thanks for the heads up the hack isn't RCE safe.
There is nothing wrong with leaving it on Region 0, then set it to Region 1 for Final Fantasy (how many times do you watch it?), then put it back to Region 0. Unlike a Firmware upgrade you're only making a minor change so I wouldn't worry about running it every now and again. There are very few RCE discs out there.
I read about that E1 workaround to play RCE discs. Personally it wouldn't bother me.
That's the million dollar question, that so far no one has cracked. Not on the BH200 or any BD Player. Given time I'm sure someone will crack it though.
Spiderman SD RC1 does not work, but spiderman 1and 2 superbit DVD, spiderman 3 DVD works. I am leaving mines at region 0, worst case i just buy it on bluray.
benc5 is offline
post #37 of 146 Old 03-23-2008, 10:57 AM
bradavon's Avatar
Thanks Benc5.
What does RC1 mean? I bet that Spider-man disc is RCE, it's a Sony title after all. Thankfully there aren't many RCE discs. I'm pretty sure all RCE discs are R1 though.
bradavon is offline
post #38 of 146 Old 03-23-2008, 01:40 PM
benc5's Avatar
Thanks Benc5.
Sorry about that, I meant Spiderman RCE region 1 don't work on region 0. I hope they get a pal hack too, then i can move my oppo 1080p player out off my shelf.
benc5 is offline
post #39 of 146 Old 03-23-2008, 10:58 PM
lorenzo1000's Avatar
Thanks to the OP, worked great for me!
Lorenzo
lorenzo1000 is offline
post #40 of 146 Old 03-24-2008, 01:26 AM
blakeBBY's Avatar
Okay quick question for you guys, many may feel it is stupid but region coding is a bit of a weakness of mine when it comes to knowledge in AV stuff. Now those who do get a PAL movie to play on your screen. Don't you need a special TV set to still display these other formats (NTSC --> PAL, PAL ---> NTSC). How does the framerate work exactly? Is it changed during upconversion, or does the player just "force" it to come to 60 Hz (for those who dont have 24fps capable)/24 Hz. I guess what I am asking is how does a PAL framerate work on an NTSC TV set.
blakeBBY is offline
post #41 of 146 Old 03-24-2008, 01:53 AM
AlfaGT's Avatar
I think that's exactly the point. Your TV must support the other format. In US your TV must support 50Hz, if it does not, your not capable of watching PAL material.
The funny thing is, that all European Hardware (I am from Europe) these days support 60Hz. So, playing NTSC movies these days is no problem on newer European TV's because they support 60Hz (since about 10 years they do).
I think I read elsewhere in this thread, that US TV's don't support 50Hz. Because that, the region hack is not so usable for US people when it comes to PAL mastered movies.
Greetings
AlfaGT
AlfaGT is offline
post #42 of 146 Old 03-24-2008, 02:17 AM
zabus's Avatar
i am living in holland my tv is able to receive ntsc and pal only the bh200 dont accept pal dvd and my player is from us
zabus is offline
post #43 of 146 Old 03-24-2008, 05:02 AM
bradavon's Avatar
He he I see the Europeans have taken over the forum, while the North Americans sleep peacefully in their beds
No not special .
PAL is a European/Australasian (it's also common in the Far East) format and as such TVs sold in Europe/Australasia commonly support PAL & NTSC as standard.
It is common to find DVD Players that have the ability to output NTSC as PAL too, for ancient TVs that cannot handle NTSC. As to American TVs pre-HDTVs most from my knowledge couldn't handle PAL but I'd imagine all if not most can now handle it. Not all HD frame rates and Hertz are 100% equal so I'd be surprised if they couldn't handle it.
Still like DVD Players/HD Players which have PAL specifically removed (or never added) they may not unless you track a particular model down. The Oppo DVD Player (I forget the other make) is known to be able to convert PAL to NTSC.
It's all a moot point sadly, if you own a USA or Canadian model as they simply don't and probably never will support PAL.
bradavon is offline
post #44 of 146 Old 03-24-2008, 05:09 AM
zabus's Avatar
bradavon thanks for your answer.i made my bh 200 region free but do you know how to change bd region(a,b and c)
zabus is offline
post #45 of 146 Old 03-24-2008, 07:10 AM
zabus's Avatar
i found thid today maybe it helps SlySoft will release a version of AnyDVD with the BD+ crack and its downloadeble
zabus is offline
post #46 of 146 Old 03-24-2008, 08:11 AM
eurotrance's Avatar
Incorrect. Region A/B Blu-Ray players have been available for months. Check out jvbdigital.com for an example.
LIVE every wednesday 12pm-2pm PST on http://www.discovertrance.com
eurotrance is offline
post #47 of 146 Old 03-24-2008, 08:19 AM
bradavon's Avatar
I meant as a mass market solution.
I know of them but they're significantly altering the players by soldering stuff to the boards. There is also a Scandinavian company which does something similar. I meant an easy to deploy software type hack.
JVB Digital (who seem to be in Holland) even offer a service to add an SDI connector to BD Players. SDI being a connection used in professional broadcast. I'd consider buying a MR BD Player from the likes of them but I want a Combo and they charge a flipping future too.
bradavon is offline
post #48 of 146 Old 03-24-2008, 10:32 AM
eurotrance's Avatar
That is not what you said, and I don't have a crystal ball. This is what your post reflects :
On top of that, do you know for a fact that it is a hardware mod and not a firmware mod ? I know of at least one person located in Switzerland that is a Sony players firmware modder wiz and the models offered all seem to be Sony's.
post #49 of 146 Old 03-24-2008, 04:15 PM
StardustOne's Avatar
My first DVD player, the famous Sony one with the motorized front, was perfectly moddable and played any region code as well as any PAL and NTSC DVD.
The stupidity of bringing HD players to the market who do not play back both tv standards is unbelieavable. Is it ignorance?
I have even heard of plain US HD-XA2 players that can be modded to play back PAL DVDs.
http://www.avforums.com/forums/showt...&highlight=xa2
Why can't this be done with the US LG BH-200?
StardustOne is offline
post #50 of 146 Old 03-25-2008, 03:38 AM
zabus's Avatar
i just had contact with lg europe and thet told me that the bd reg code is a matter of changing in the service menu as well as the possebillity to change the player into into dubbel position pal/ntsc is also a code to change in service menu but the only one who could give these codes is lg usa
zabus is offline
post #51 of 146 Old 03-25-2008, 03:49 AM
bradavon's Avatar
I just don't think there is much of a market for it North America.
That's impressive.
That's interesting. That's surprisingly honest of LG to tell you that.
I would guess Julio Cohen found this Service Menu to enable SD DVD MR. If someone could find the one to make it PAL & NTSC plus BD MR that would be amazing.
bradavon is offline
post #52 of 146 Old 03-25-2008, 05:43 AM
blakeBBY's Avatar
No not special .
Well I know the differences between the actual standards. But getting them to play is a whole different story. Are you claiming, that with this multi region hack, it will basically convert a PAL DVD to output as NTSC? Almost like upconverting a 480i image to HD 720, 1080?
Im 95% positive will only accept a 60 hz signal. Its fairly old Mitsu DLP. I dont own this player but it is something I am considering for maybe a little bit down the road. Would this be able to take a PAL disc and output it as NTSC?
blakeBBY is offline
post #53 of 146 Old 03-25-2008, 05:52 AM
bradavon's Avatar
No not at all. Sorry if I implied I was.
I don't believe the BH200 can do that.
bradavon is offline
post #54 of 146 Old 03-25-2008, 06:31 AM
blakeBBY's Avatar
Okay I am just making sure. It really wouldn't be anything I would HAVE to have anyway. Just a few select titles that are only available in the UK I wouldn't mind owning. It would have been pretty cool if that would have worked out. Thanks for the info.
blakeBBY is offline
post #55 of 146 Old 03-25-2008, 07:27 AM
BrotherEstapol's Avatar
Just a question...if I got a BH-200 from the US(I'm in Australia), and applied this hack, my PAL DVDs would play on it fine?(since my TV supports PAL of course)
Also the BD region would be A since I got it from the US?
Cause it looks like at this point I can only get one from the US, and at this stage I'm more than happy to import US BDs instead of buying discs locally.(at double the price!)
While obviously the HD DVDs would play no worries since they're all region free.
BrotherEstapol is offline
post #56 of 146 Old 03-25-2008, 07:52 AM
bradavon's Avatar
Correct and Correct. It's the Player that doesn't support PAL and chucks it out regardless of your TV.
bradavon is offline
post #57 of 146 Old 03-25-2008, 02:28 PM
bolmsted's Avatar
Originally Posted by dickydoo View Post
I don't have a new receiver to test bitstreaming, but Dolby TrueHD is still downmixed to DTS 5.1 over SPDIF.
And it always will.... Dolby TrueHD cannot be sent over SPDIF, but instead must be downmixed and sent over as either Dolby Digital or DTS as you have discovered - not enough bandwidth to support it. Why would they send it as DD(640Kbps) if they can send as DTS (1.5Mbps)
bolmsted is offline
post #58 of 146 Old 03-25-2008, 02:52 PM
oilblue's Avatar
Splitting hairs here...but, prior to LG's March firmware, Dolby TrueHD output over SPDIF was limited to 2-channel PCM.
With that in mind, dickydoo may have been pointing out a positive aspect of the MR hack (i.e. the MR hack doesn't mangle the newfound multi-channel DTS output of TrueHD tracks).
oilblue is offline
post #59 of 146 Old 03-25-2008, 03:00 PM
bradavon's Avatar
Cannot you still get it to do that depending what audio option you choose? If there was a TrueHD 2.0 track it would be the way to go.
The hack just makes the BH200 region free, it doesn't change anything to do with audio. I asked Dickydoo if it also removes the March firmware (i.e - by stuffing something up) and he was reporting it doesn't.
bradavon is offline
post #60 of 146 Old 03-25-2008, 03:09 PM
peterjcat's Avatar
Just to clarify -- BrotherEstapol wants to know whether the multi-region hack will allow the US BH200 to play PAL DVDs; your first "Correct" implies that it will, but your second sentence implies that it won't.
BrotherEstapol, unless I've missed something the reports suggest that your BH200 won't play your PAL DVDs even with the current hack. Future hacks may allow it though, like the hacks to all the US Toshiba HD-DVD players.
Just trying to help out a fellow Aussie. (My BH200 should be arriving today, fingers crossed.)
peterjcat is offline
Reply Dual Format Players
