BH200 Setup Questions (Denon 3808/Samsung 650 Series LCD) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-14-2008, 10:32 AM - Thread Starter
cbolton's Avatar
Hello,
I have all of my gear now after CEVA was a bit late delivering the television this week. I have the 3808 conntected to the 650 LCD via the HDMI monitor output and the BH200 connected to an HDMI input. I assume that I will not experience a loss of picture quality by using the HDMI switching capabilities in the 3808...
I am getting a picture now (I Am Legend Bluray looks awesome btw) but I am still working on optimizing the picture and the audio. I am looking for some help optimizing the picture quality and audio from the BH200:
The Denon 3808CI has an I/P scaler function that I have turned off at the moment - I didn't think that was needed for this player but I wasn't sure if that was the right thing to do?
Since the 650 Series supports 1080P/24 I assume I want that enabled on the BH200 but I don't see it as an option. I have the resolution on the player set to 1080P with Qdeo video mode and the manual seems to indicate that the player enables /24 automatically based on a handshake with the other components? Is there anything I have to do on the receiver side to support this (doesn't look like it)?
I have the player set to HDMI "PCM Multi-Ch" 192kHz for audio so that the 3808 will decode the audio . I am not seeing DolbyTrueHD or DTS Master audio show up on the display as of yet - is there another setting I should use to access the new audio codecs (I have the track selected on the disc)?
Any other things I should be looking at with this setup would also be helpful!
cbolton is offline
post #2 of 6 Old 05-14-2008, 10:55 AM
bradavon's Avatar
With the March or April firmware you can force 24Hz support. I understand set to Auto it doesn't always work.
PCM Multi-Ch will output TrueHD as Lossless PCM and DTS-HD as the DTS Core (1.5Mbps) as PCM (but not Lossless). That's why your Amp isn't picking up TrueHD/DTS-HD, as it's receiving PCM. As your Amp supports TrueHD/DTS-HD you want to set the BH200 to Primary Pass-Thru not PCM Mult-Ch.
PCM Multi-Ch converts everything to PCM and doesn't send it as Bitstream for your Amp to decode.
I have the player set to HDMI "PCM Multi-Ch" 192kHz for audio so that the 3808 will decode the audio.
Wrong way round. With it set to PCM Multi-Ch it's the Player which does the decoding. Primary Pass-Thru lets the Amp do the decoding.
bradavon is offline
post #3 of 6 Old 05-14-2008, 11:38 AM - Thread Starter
cbolton's Avatar
Bradavon - thanks for the reply.
HDMI pass through fixed it - awesome!
How do I force the 24Hz setting? I did the firmware update. Also, is there anything I need to do on the BH200/Receiver for deep color support?
cbolton is offline
post #4 of 6 Old 05-14-2008, 11:52 AM
efjay's Avatar
For 1080/24 go to Home, setup, Other and set Film mode to On. Dont bother yourself about deep colour as no disc supports it.
efjay is offline
post #5 of 6 Old 05-14-2008, 12:19 PM - Thread Starter
cbolton's Avatar
Thanks efjay - I saw that option but wasn't sure what it was. 1080P/24 = Film Mode, makes sense
cbolton is offline
post #6 of 6 Old 05-14-2008, 01:29 PM
efjay's Avatar
No problem, sit back and enjoy
efjay is offline
Reply Dual Format Players
