Samsung BD-UP5000 Firmware 1.3 Released Report BUGS\FIXES - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 885 Old 05-30-2008, 10:47 AM
Hogweed75's Avatar
Originally Posted by pobff View Post
OMG. My TV displays the hardware that's playing...it says "BD-P1500" instead of "BD-UP5000".....
And there were flickers at the start of I Am Legend HD DVD at the menu and few seconds after the movie is selected.
I didn't notice this. Will have to look when I get back home but we do know that it is playing Blu-Ray's and HD-DVD's correctly!
Cary Cinema 12 Pre/Pro, XPA-3 & UPA-2 Amps.
2 DIY Vifa 12" Subs, HTPC-3D, Moncaso 301P, Svr: Norco RPC-4020-24TB WHS.
Ctr:ML Motif, Rrs:ML Fresco i w/Abyss sub.
Hogweed75 is offline
post #92 of 885 Old 05-30-2008, 10:50 AM
jimjr's Avatar
Originally Posted by texrb View Post
Ok I an confirm that DTS-MA is being output (played i-Robot BD) & True-HD (from Harry Potter - Phoenix HD-DVD). I have the 5000 set to Bitstream-Audiophile thru HDMI to my Yamaha RX-V663. Don't know if it's bitstreamed or decoded since my AVR can decode. I can also confirm DD+
Unless I have my terminology incorrect, "decoding" refers to the process of converting the signal from its original format (TrueHD, DTS, DD, whatever) to PCM at the player level (i.e. "internal" decoding) and then outputting that decoded to PCM signal over analog, optical, HDMI. If your receiver is showing the DTS-MA and TrueHD flags, that tells me that you are passing the original signal undecoded and letting your AVR do the decoding. If the 5000 was doing it, you'd probably only be seeing some kind of PCM signal on the receiver.
jimjr is offline
post #93 of 885 Old 05-30-2008, 10:56 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Audio dropouts have seemingly vanished from Warner HD DVDs (well, Michael Clayton anyway) as well as the Paramounts (Things We Lost in the Fire and Beowulf). I noticed some 24fps flickering (though minor compared to Beowulf) on Things We Lost... as well. The PCM "pop" seems to have been resolved also (experienced when navigating and resuming playback on discs with PCM; in this case, Prestige).
vinnie97 is offline
post #94 of 885 Old 05-30-2008, 11:02 AM
bradavon's Avatar
Sorry if this has been answered in the last 4 pages:
Confirmed:
Profile 1.1 support
TrueHD on-board decoding - Analogue or HDMI
TrueHD converted to DTS - SPDIF
DTS-HD MA bitstream
TrueHD Bitstream
DD+ Bitstream
What about? -
DD+ On-board
DTS-HD MA On-board - HDMI
DTS-HD MA On-board - Analogue
That would bring it in line with the LG BH200 (except for it's hacking capabilities). To clarify the LG BH200 can only Bitstream DTS-HD HR and MA.
bradavon is offline
post #95 of 885 Old 05-30-2008, 11:03 AM
carljanderson's Avatar
Originally Posted by bradavon View Post
What about? -
TrueHD Bitstream
DD+ Bitstream
Yes on both.
Waiting for my 2012 upgrade...
carljanderson is offline
post #96 of 885 Old 05-30-2008, 11:03 AM
pobff's Avatar
I think these two are confirmed:
TrueHD Bitstream
DD+ Bitstream
Update: Carl beat me to it. :P
Upgrade firmware via Ethernet port
-The 1.3 firmware is not available yet but it's been available for firmware 1.2 already. That's how I updated mine when I first got it.
pobff is offline
post #97 of 885 Old 05-30-2008, 11:07 AM
The 5000 has always been able to update via the ethernet port. The only exception was when firmware 1.1 killed the network port.
post #98 of 885 Old 05-30-2008, 11:16 AM
Fatawan's Avatar
Originally Posted by Foxbat121 View Post
Good tip. I'll try it later.
You appear to be our only possible test subject with a DTS-HD MA 7.1 disc to try.......the world awaits your results.....
Fatawan is offline
post #99 of 885 Old 05-30-2008, 11:20 AM
bradavon's Avatar
Thanks guys.
It sounds like we just need to confirm if DD+ is also on-board (likely) and DTS-HD MA is also on-board (unlikely)?
If your Amp is receiving a PCM signal none of the DTS-HD/TrueHD lights will light up.
Bitstream Audiophile sounds like it Bitstreams too.
Originally Posted by p-g-m View Post
this thread should be a sticky
I don't think that's necessary. There are several threads that could be stickied but before we know it we'd have half a dozen threads.
Originally Posted by carljanderson View Post
My Yamaha shows DTS-HD MSTR is being input as 7.1, even though the disks are 5.1 DTS-HD MA.
It sounds like it has the same bug as the LG BH200 then:
http://www.avsforum.com/avs-vb/showthread.php?t=1027202
bradavon is offline
post #100 of 885 Old 05-30-2008, 11:20 AM
p-g-m's Avatar
Yeah, Foxbat, we're still waiting...or anybody else, please check the DTS-MA decoding
p-g-m is offline
post #101 of 885 Old 05-30-2008, 11:25 AM
bradavon's Avatar
Of course it gets tricky because telling the Samsung to output PCM (on-board) and not bitstream will mean you either get:
DTS-HD MA converted to PCM
The DTS Core
Both will give you 5.1. I guess you'll need to compare it with HDMI and SPDIF to see if you can hear any difference.
bradavon is offline
post #102 of 885 Old 05-30-2008, 11:25 AM
Rightonbeat's Avatar
They probably used most of the code from the 1500, to write the 5000 firmware, and forgot about the hardwear ID embedded in it.......
So look for an update in the next few days with that and maybe few other things addressed..............
to wait or not to wait that is the question!
RIGHTONBEAT
Rightonbeat is offline
post #103 of 885 Old 05-30-2008, 11:28 AM
p-g-m's Avatar
I've been waiting for this update ever since I got the player in November. I deserve to have it on top of the page and not search for it between the other "more" important threads
p-g-m is offline
post #104 of 885 Old 05-30-2008, 11:29 AM
bradavon's Avatar
I imagine it's going to stay at the top anyway .
bradavon is offline
post #105 of 885 Old 05-30-2008, 11:36 AM
p-g-m's Avatar
One of those days I'd love to see someone hack the player, and make it support PAL, SD DVD and BD region free. How great would that be!?
Of course, DTS-MA support is more important, so one step at a time, I guess
p-g-m is offline
post #106 of 885 Old 05-30-2008, 11:38 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
450 MB of persistent memory showing instead of 128MB.
Since DTS-HA MA is bitstreamed, I don't think it is the bug of player (player has no idea). Either disc authoring problem or your AVR has a bug.
You know work is a bitch. I already missed 2 hours of work in the morning. Let me see if I can sneak out earlier this afternoon.
Foxbat121 is offline
post #107 of 885 Old 05-30-2008, 11:39 AM
Actually, I think it is with the player. The 5000 exhibited the same bug on PCM tracks prior to FW 1.3.
post #108 of 885 Old 05-30-2008, 11:40 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
The DTS Core
There are discs that have DTS-MA 7.1. DTS core is 5.1 only.
post #109 of 885 Old 05-30-2008, 11:53 AM
bradavon's Avatar
This would probably be better discussed in the Main Samsung thread but has anyone tried any of the Samsung Player hacks out there?
The hack for the LG BH200 to enable PAL/BD Region support was originally for one/some of their DVD Players.
bradavon is offline
post #110 of 885 Old 05-30-2008, 11:54 AM
Fatawan's Avatar
I just did a little experiment, but I have no idea what the results mean. I set the 5000 to PCM and put in "Rise of the Silver Surfer", which is DTS-HD MA 5.1. I chose that track for my audio. On my Onkyo pre/pro, it said "MultiChannel PCM", and listed the frequency sampling at 48kHz. DOH! Now that I think about it, I should have chosen the Dolby Digital track as well and see if it changed anything. Maybe later. However, I then went to bitstream audiophile, and restarted. The Onkyo says DTS-HD MA and lists the frequency sampling at 48kHz once again. FWIW
So the question is, with the 5000 set on PCM, and obviously outputting PCM to the Onkyo, with the audio track chosen as DTS-HD MA, would it output nothing if it was unable to decode onboard??? I definitely had 5.1 output.
Fatawan is offline
post #111 of 885 Old 05-30-2008, 11:57 AM
bradavon's Avatar
No you'd get the DTS Core.
I imagine 48Khz is correct and that's what the track is encoded with.
bradavon is offline
post #112 of 885 Old 05-30-2008, 12:02 PM
Fatawan's Avatar
Dang! I might have to run out to Best Buy and get Pan's Labyrinth
Fatawan is offline
post #113 of 885 Old 05-30-2008, 12:06 PM
clarkk41's Avatar
Is pans the only one. Shoot em up should work ok i think. I believe that is dts hd ma 7.1 as well.
clarkk41 is offline
post #114 of 885 Old 05-30-2008, 12:12 PM
bradavon's Avatar
Surely the quality should be obvious regardless of 7.1? If you cannot tell the difference then I wouldn't worry either way . Just don't pick something like Rambo 1-3 to test it now .
Although it would be nice to be confirmed.
Rambo 4 (USA BD) is also DTS-HD MA 7.1
bradavon is offline
post #115 of 885 Old 05-30-2008, 12:13 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Every DTS-HD MA track contains a DTS core track that can be decoded by any DTS only player. 5k can decode DTS core from day one.
post #116 of 885 Old 05-30-2008, 12:16 PM
dougotte's Avatar
Quoted: 117 Post(s)
Liked: 68
One time I tried switching from PCM to Audiophile, and the AVR still reported it was receiving PCM. Changing the 5k audio setup might require a power cycle before it "takes." Did you power off/on before your second test? I'm sure others who have more experience playing with the audio settings can chime in and debunk my test.
Doug
dougotte is online now
post #117 of 885 Old 05-30-2008, 12:19 PM
Fatawan's Avatar
Pan's Labyrinth, The Orphanage, Rush Hour 3, Golden Compass, Hairspray, Saw 4, Shoot Em Up, OldBoy, Mr. Woodcock, and Dr. Strange:The Sorcerer Supreme
Those are your 7.1 choices
Fatawan is offline
post #118 of 885 Old 05-30-2008, 12:22 PM
john19's Avatar
I have been looking around but must have missed it is the update ready for ethernet also or just burn to cd?
john19 is offline
post #119 of 885 Old 05-30-2008, 12:29 PM
GizmoDVD's Avatar
This or the LG?
GizmoDVD is offline
post #120 of 885 Old 05-30-2008, 12:38 PM
rded's Avatar
Quoted: 29 Post(s)
Liked: 37
Add Rambo to that list -7.1 DTS HD!
rded is offline
Reply Dual Format Players
